[OK] B&M 144 Supercharger and belts/pulleys $800
For sale:
Used B&M 144 Supercharger, Teflon seals, Boosted great, at 6lbs on a 350. Comes with crank pulley and belts, and tensioner. Lower intake and thermostat elbow. Ready to bolt on and go.
A carb screw did fall into the rotors, this does not affect performance, it boosts fine. I have pics upon request. It is unpolished.
I found a really good deal on buick GN drivetrain so Im selling all of my SBC stuff. $800 obo. Plus shipping, Will ship ANYWHERE in the upper USA.
Re: B&M 144 Supercharger and belts/pulleys $800
Bumpity bump bump. If you are unsure about the condition, PM me for pics. This supercharger can make 12lbs of boost on a 350 with a different lower pully, pulleys can be bought on ebay CHEAP!.
Car: 91 Camaro
Engine: 383 carbed/headers/nitrous
Transmission: th400
Axle/Gears: Chevy 12 bolt w/411 gear
I would like to see some those pics pm me with them
Car: 91 Camaro
Transmission: th400
I spoke to you yesterday would you mind sending me some pics of the other parts intake pulleys and so forth
bump!, give me $700 plus shipping and its yours!. ill take trades as well. aftermarket suspension parts, buick gn stuff, front mount intercooler,cash.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
really wish i had the money man, i would love to use this... plus i'm tbi so its pointless for me.. this is such a good deal! fml..
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Any idea if you can get one of these to work with a stock A/C system installed. I have no desire to get rid of my ac.
As for tuning, a tuner would be able to tune it for you, I think the TBI ecm uses an EPROM. the advantage to having a factory ECM, it uses a knock sensor, so if it detects knock, it pulls timing, you could put 454 injectors in, increase fuel pressure a lil and tune it and gain some HP.
Im not sure if it will work with the stock A/C. The long nose is designed to work around pulleys and bolt to the lower pulley on the crankshaft, I dont know what interferes if this blower is installed with factory serpentine setup.
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Ah, my car isn't serpentine, it's a v belt. 84 z28 l69 305. I'd love to have it but I have no desire to get rid of my a/c at the expense of power seeing as it's my DD at the moment.
should work fine with v belts, the nose sticks out far enough to clear the pulleys. the lower pulley bolts on the stock lower crank pully, the supercharger has its on belt and tensioner, you should not lose ur ac or power steering.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
damn i really want the supercharger
fml... Only shitty part is i dont want to get bigger injectors, i just want to bolt on an go, lol
fml... Only shitty part is i dont want to get bigger injectors, i just want to bolt on an go, lol Thread
codeysabatini
Nov 10, 2015 04:07 PM
