[OK] 377 stroker rotating assembly, 1pc rear main,Eagle Crk,i-Beams,Probe Pistons,&MISC
Old May 17, 2010 | 04:34 PM
MPIpowered4x4's Avatar
FOr sale, 377 Stroker, 1 piece rear main seal rotating assembly. The crank has about 50 miles on it, STD/STD, Eagle Cast, 350 main journals, 3.75 stroke, externally balanced.
Scat I-beams,5.7 length, 50 miles on these, 4 rods are clearanced to clear the camshaft, I was running a LT4 hot cam at this time. You need to clearance the other 4 rods before balancing. Machine shop can do this if you want them to.
Pistons, Probe, STD 4.00 bore,5.7 rod stroker pistons, flat-top molleculite , Aprox 10.6-1 with 64cc heads, lightweight forged pistons, 50 miles on these as well. Pressed on the rods, the pistons are floating, but I used them on pressed pin rods. The pistons alone cost $450.
This stuff is ready to be balanced and go into your block. $500 plus shipping.
I have pics, but I do not sell junk and I do not want to ruin my rep on here.
Im changing over to a Buick GN setup, so ALL of my SBC stuff is for sale.
I have a HEI distributer with MSD wires, distributer is slightly used, high power coil, aluminum body. $75 plus shipping
Reman Hydraulic roller lifters, and spyder for 87+ roller blocks, Erson hardened push-rods stock length,Roller tipped 1.6 rockers, $150 obo, plus shipping. All of this stuff has less than 50 miles on it.
ARP head bolts, USED, SBC, $30 plus shipping.
mhatfield 14
Oct 24, 2015 07:48 AM
hectre13
Aug 26, 2015 08:17 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
