[OH] Lots of TPI and Fbody parts for sale
Old Jun 6, 2010 | 02:46 PM
25th92RS's Avatar
Car: 1992 RS, 2000 Z28
Engine: LO3 with TPI Swap, LS1
Transmission: 700-R4, 4L60E
Axle/Gears: 3.42 with TruTrac LSD
I'm cleaning out my garage of parts. Need to get rid of EVERYTHING listed.
Make an offer on something you think you need and I will make my considerations.
-1985 TPI intake base - **SOLD**
-1985 TPI intake base heavily ported and modified for Vortec heads - **SOLD**
-9th Injector for 85-88 Fbody/Corvette - **SOLD**
-Air Duct for 85-88 IROC (duct between TB and MAF sensor) - **SOLD**
-MAF sensor from 1985 IROC - **SOLD**
-Distributor Cap & Coil (large cap with coil in cap)
-Distributor Cap & Rotor (brand new in box, coil in cap)
-Single Cooling Fan with all brackets
-Radiator (untested for leaks, can do that for you if wanted)
-2 sets of ignition wires for sbc
-10 Bolt 7.625 inch Open differential from my 1992 Camaro RS with 2.73 ring&pinion included 118,000 miles on gears and diff
-March Power Pulley set with belt - **SOLD**
-1985 IROC rear seat bottoms, Black with Red piping (bottoms only unfortunately)
-Water Pump with pulleys, cast iron
-14 inch Chevrolet open element air filter for Carb or TBI - Pay Shipping Only
-Stock black valve covers off of 305 TBI
The stock intake base listed has been completely cleaned and bead blasted and is like new! Absolutely no carbon build up left on or in it.
The ported and modified to Vortec intake base is cleaned but will probably get blasted and would look much better with a paint job due to some of the mods on it. I did not do the mods but can tell you as much about it as the guy who I bought it from. Just ask and I'll give you some info and pictures.
I can supply pictures for anything listed at request. I'd put them up here but there's too many pictures to post.
I also have a set of 1985 runners, Plenum and Throttle body but am in the middle of refurbishing and removing dents from the runners. They came off of the stock base listed above. I'd be willing to part with them as I do not need them but like I said they are in the middle of being refurbished, cleaned and polished.
Old Jun 6, 2010 | 03:07 PM
25th92RS's Avatar
Re: Lots of TPI and Fbody parts for sale
Old Jun 6, 2010 | 03:11 PM
92rs25's Avatar
Want a title? Post!
Car: 1992 Camaro RS
Engine: 5.0 305ci TBI
Axle/Gears: 3:42 swap
can i get pics of the runners and the rest of the stock 1985 tpi parts please
Old Jun 6, 2010 | 03:32 PM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Details on the march power pulleys please? Do you know the part number or what years they fit?
Old Jun 6, 2010 | 03:40 PM
25th92RS's Avatar
The part number is 04000 and they are for Camaros and Firebirds 88-92. These were on my car when I bought it and I removed them to put the stock pulleys back on. No reason for it, nothing wrong with this set at all besides they could use a repaint but don't really need it. Let me know if you want them. Definite seat of the pants difference. I know my car is definitely slower when I took them off.
Old Jun 6, 2010 | 03:44 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Did the alternator charge at idle or would it drop off?
How much shipped to 43964?
Old Jun 6, 2010 | 04:03 PM
25th92RS's Avatar
It charged at idle but you could see voltage dip and come back with your turn signal blinking at a stop light. Never really noticed any detrimental voltage loss. You could probably even use the crank pulley in this kit with your stock alternator pulley and possibly alleviate that problem and would still gain some power from accessory drag loss but never tried it.
30 bucks shipped fair enough?
Old Jun 6, 2010 | 04:34 PM
25th92RS's Avatar
Here are a few pictures. As I had said, they are in the middle of refinishing so they're clean, ALL carbon has been removed, but not yet finished to where I'd like them to be besides the base manifold, it is done. But would part with them if someone wants them since I really do not need them just wanted to make a nice set of parts for others to have.
Intake Base - SOLD
Attached Thumbnails Lots of TPI and Fbody parts for sale-img_1230.jpg   Lots of TPI and Fbody parts for sale-img_1231.jpg   Lots of TPI and Fbody parts for sale-img_1232.jpg
Old Jun 6, 2010 | 04:37 PM
25th92RS's Avatar
and a few more pics. The plenum has been hand ported at the TB openings to 58mm. I bought it that way so it was not ported by me. Decent job was done but could be rounded out slightly better.
Also, all of these parts came off the same car
Attached Thumbnails Lots of TPI and Fbody parts for sale-img_1233.jpg   Lots of TPI and Fbody parts for sale-img_1234.jpg
Old Jun 6, 2010 | 05:59 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
PM being sent.
Old Jun 6, 2010 | 10:08 PM
25th92RS's Avatar
Stock intake base has sold. The ported and modified for Vortec base is still available. I can post pictures of that one tomorrow.
The power pulleys have sold also.
Old Jun 7, 2010 | 04:36 PM
25th92RS's Avatar
bump
Old Jun 7, 2010 | 06:32 PM
Workman1788's Avatar
Car: 1988 Formula 350
How much for the plenum, runners, TB, and ported base? Or even individual prices. I'm just south of medina so I could pick up.
Old Jun 7, 2010 | 09:01 PM
25th92RS's Avatar
$60 for the base ($80 if you want it blasted and painted, it'll need painted)
$40 for the plenum
$30 for the runners as they sit. I'll get rid of all dents for $50
$30 for the throttle body
So, for $160 you get it how it sits and for $200 you get it how it should be and I do the work which would probably take me a weekend to get done maybe a little longer depending on my schedule. And I might have all the hardware to put it together or most of it but I'd probably have to dig to find it all.
I wanted to polish the plenum, runners and TB so they've been sanded very lightly but I can get the finish to match by just bead blasting them again to even it out. And I'd want you to come see the base, especially since you're so close. There's A LOT of modifications done to it but also done VERY well. How the guy I bought it from modified it for Vortec heads, I don't know but it's almost flawless. I'll post a few pictures but I think you're going to want to see it first.
PM me if you're interested and stop by sometime this week and check it out.
Old Jun 7, 2010 | 09:07 PM
dpmalibu's Avatar
pics of the 14" TBI air cleaner and price please
Old Jun 7, 2010 | 09:10 PM
25th92RS's Avatar
It's hard to tell not right next to a stock intake base. But the runner ports are slightly larger than the ports on my TPiS BigMouth base and the cylinder head side ports are huge. As you can see around the sides it has some bondo or bondo-like filler on it that I didn't discover until I stripped it of the paint that was on it. But seems to be solid and is probably just covering up where they added material for the vortec sized mounting flanges.
And this came off of a 406 small block pushing 500+ HP
Attached Thumbnails Lots of TPI and Fbody parts for sale-img_1241.jpg   Lots of TPI and Fbody parts for sale-img_1242.jpg   Lots of TPI and Fbody parts for sale-img_1243.jpg
Old Jun 7, 2010 | 09:12 PM
25th92RS's Avatar
a few more pics
Attached Thumbnails Lots of TPI and Fbody parts for sale-img_1244.jpg   Lots of TPI and Fbody parts for sale-img_1245.jpg
Old Jun 7, 2010 | 09:35 PM
25th92RS's Avatar
Here's a picture.
After thinking about it a minute all I want is the shipping cost so send me your zip code and I'll get a shipping estimate for you and that'll be all I want out of it.
I just want it gone. I have no carbed cars and the TBI will be out of my Camaro in probably the next year as I'm building a TPI motor.
Old Jun 7, 2010 | 10:01 PM
dpmalibu's Avatar
I'm gonna pass. thanks anyway.
Old Jun 7, 2010 | 11:34 PM
25th92RS's Avatar
It's no problem man. Thanks for the inquiry
Old Jun 8, 2010 | 05:15 PM
25th92RS's Avatar
bump...
Old Jun 9, 2010 | 08:43 AM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Bump for a great seller.
The March pulleys showed up today as described. Thanks for the great deal 25th92RS!
I left you a classifieds rating.
Old Jun 9, 2010 | 12:11 PM
mvp2ceo's Avatar
Car: 87 IROCZ
Transmission: 700R4 shift kit, corvette servo...
Axle/Gears: 26 spline 4.10 mini spool
will the 85 MAF work on an 87 305? if so how much?
Old Jun 9, 2010 | 12:32 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
Distributor Cap & Rotor (brand new in box, coil in cap) what brand is it?? pics or part #
Old Jun 9, 2010 | 08:15 PM
25th92RS's Avatar
To answer your question I really don't know if the part will interchange between years because I have heard and read before that the 85 sensor is a one year only part. I don't know how true that is, however.
But you're just barely too late on it. It sold this afternoon and haven't had a chance to update anything yet. Sorry.
Old Jun 9, 2010 | 08:29 PM
25th92RS's Avatar
Brand - GP Sorensen
Part #'s - DR109 & DR112
Parts were removed from box for pictures only.
Old Jun 9, 2010 | 11:00 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Interested in the 85 base. Do you still have it?
Old Jun 10, 2010 | 10:41 AM
25th92RS's Avatar
The stock base I do not have. It sold a few days ago.
The modified base I do still have but it is modified for Vortec heads and is heavily ported. If that's what you are looking for, than it is still available. Let me know. Price is $60 plus shipping.
Old Jun 10, 2010 | 09:06 PM
25th92RS's Avatar
bump...
Old Jun 11, 2010 | 02:24 PM
25th92RS's Avatar
1985 TPI Intake duct, SOLD
Old Jun 12, 2010 | 02:01 PM
25th92RS's Avatar
bump...
Old Jun 12, 2010 | 10:44 PM
IWANNAROCAGAIN's Avatar
Car: 91 Z28 Convertible
Axle/Gears: 3:42
Is the vortec base still available?
Old Jun 13, 2010 | 08:00 AM
25th92RS's Avatar
The vortec base is still available. For $60 plus shipping it's yours, or come pick it up if you're close.
If you want, I can clean it up a bit more and paint it for you as well for $80.
Old Jun 15, 2010 | 07:54 AM
25th92RS's Avatar
Bump....
Old Jun 15, 2010 | 09:29 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Is it for vortec heads or just the 87 and up center bolt heads. There is a big difference?
Old Jun 15, 2010 | 10:25 PM
25th92RS's Avatar
Oh yeah, there is a huge difference. This is an OEM casting, dated 1985. It has been heavily modified to bolt to Vortec heads. Material has been added to the outer flanges to fit Vortec heads. In no way will this manifold fit standard chevy cylinder heads, center bolt or perimeter bolt. The mods are done extremely well and I, personally, can't even see seems or welds where it has been modified. So, Vortec heads or Vortec bolt pattern heads, like GM Fast Burns. 4 bolt flanges, not 6 bolt.
There are pictures in the thread above. Look closely if you are thinking of purchasing this. If you live close, feel free to arrange a time with me to come see it or if you want more pictures please ask and I can send more to you. I wouldn't want you to buy it and then it not be what you were actually looking for. I am only selling it because I am not using Vortec heads on my build. Otherwise I'd use it.
It is HEAVILY ported as well. Intake runners are larger than any aftermarket casting available.
Old Jun 18, 2010 | 03:16 PM
25th92RS's Avatar
bump...
Old Jun 18, 2010 | 06:37 PM
ninetyone's Avatar
Axle/Gears: 3:42
Did you say that the vortec base was sold?
Old Jun 18, 2010 | 11:41 PM
25th92RS's Avatar
No, the Vortec base is definitely still available! Let me know if you want it, 60 bucks plus shipping.
And like I've offered everyone else who has inquired about it. I can clean it up a little bit more than it already is and I will paint it also (color of your choice) for an additional 25.
Keep in mind this is not an aftermarket base. It is a stock base modified to fit vortec heads and is also HEAVILY ported. Check out the pictures up farther in the thread and those are a pretty good representation without seeing it in person. Keep me posted. Thanks!
Old Aug 22, 2010 | 03:33 PM
ninetyone's Avatar
Axle/Gears: 3:42
I know this is an old thread,but do you still have the Vortec base for sale?
Old Aug 22, 2010 | 05:03 PM
25th92RS's Avatar
Nope, sorry man. It sold not too long ago. I should have updated this to indicate so.
Old Oct 11, 2010 | 11:42 PM
  #42
Kolby's Avatar
Car: 1988 Trans Am GTA
Engine: 350 5.7
I didnt know you could modify the intake to make it suitable for vortec heads. Mind pointing me in the right direction to do so? Good luck with the sales.
Old Oct 12, 2010 | 09:57 PM
  #43
kustomiser's Avatar
how much for the plug wires,cap and rotor shipped to 31520
Old Oct 18, 2010 | 11:44 AM
  #44
25th92RS's Avatar
I personally wouldn't know all the details that went into the conversion as the converted intake I had was not done by me. I bought it from the guy who did do it. I can tell you there was a hell of a lot of material added to the intake to cylinder head flanges and this guy who did it did an amazing job, after bead blasting the entire intake I could not find a single weld seam on that intake base. Not for the amature to attempt but if you got some *****, go right ahead and dive into it but you're probably better off getting yourself an Edelbrock or Scoggin Dickey Vortec intake base for a few hundred bucks rather than hacking into a few stock bases and risking messing every single one up unless you've got skilled hands with metal forming and TIG welding. Not to mention the amount of porting you'll have to do to a stock base to even take advantage of the Vortec heads. That converted stocker I had not only had the vortec flanges but it was ported out slightly larger than a TPiS BigMouth base all the way from the runner flange to the cylinder head flange. The guy put some serious bench time into it, came out unbelievable though I believe the the Edelbrock and SD are the same casting and the SD base may not even be manufactured anymore.
Old Oct 18, 2010 | 11:54 AM
  #45
25th92RS's Avatar
If you want all of the new-in-box parts I'd get them to you for 25 bucks.
31520 is Brunswick, GA, right?
I do have used parts of each but they are pretty well used. Let me know if you still want these parts.
Oh and the new parts do not include a coil. I believe my used cap has a coil still in it.
Old Oct 18, 2010 | 06:30 PM
  #46
Cornflakekid's Avatar
do you have an 85 tpi wiring harness by chance? How much if so? Thanks, Jeremy
Old Oct 18, 2010 | 07:14 PM
  #47
25th92RS's Avatar
Unfortunately I do not have a harness for an 85. All those 85 parts I have I acquired through other deals so nothing was really complete. Sorry man. Good luck in the hunt. I had a hell of a time finding a speed density harness for my build. Keep at it and don't settle for someone ripping you off by way overpricing something.
Old Oct 18, 2010 | 07:27 PM
  #48
jake.sala's Avatar
How much for the fan? and can i see some pics,
thanks
Old Oct 21, 2010 | 06:24 PM
  #49
25th92RS's Avatar
thanks
30 bucks plus shipping.....
Old Oct 22, 2010 | 08:23 PM
  #50
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
You don't happen to have a manual steering column do you?
jaridjohn
Jul 8, 2024 03:49 PM
hectre13
Dec 11, 2023 08:14 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
