Ground Control Weld in weight jack kit
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
New never used. Springs are from Suspension Spring Specialist purchased from Spohn that have been powdercoated.
Front springs are 650#
Rear springs are 150#
[IMG]
[/IMG]
550.00 Shipped
I will accept paypal if you cover the 3% fee.
[IMG]
[/IMG]550.00 Shipped
Car: 87 GTA
Re: Ground Control Weld in weight jack kit
Ummm.......It looks like you have 4 front jacks but no rear jacks there.
Here is a pic of my rears on the left, fronts on the right......
Ummm.....no they're front and rear. Trust me. The rears are not the inferior coil over adapter kind they're weld in like the front. Much easier adjustment.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yeah stephen, his kit is not the same as your (obviously). His is more of a univesal set that mounts the weight jacks with the adjuster bolt up. So in the front you would be drilling a hole in the k-member spring pocket and into the engine compartment for the bolt, so you adjust the height from under the hood. And the rear would be the same idea drill a hole in the frame rail and put the bolt up in the hatch area.
HOWEVER, the rear setup in the OP's pics, do NOT have the pigtail, so it would not work on a 3rd gen without different springs or modifiying the spring perch on the axle.
So again this is a universal kit and not the 3rd gen kit that Ground control sells.
Last edited by //<86TA>\\; Jul 3, 2010 at 10:58 AM. Reason: no need for that sorry
Car: 87 GTA
Car: 87 GTA
If you look at the left set of springs, at the very bottom next to the box, they do appear to be rear pigtailed springs. I thought they weren't too, the first time I looked.
It's not the universal kit. I can post the receipt. Albeit it's not a good pic. They are rear springs. Anybody care to make a $500 bet with me.
Car: 86 Trans Am
Car: 86 Trans Am
I the GC's jack setup they sell now, the one Stephen posted. Im just using the fronts, and they adjust from under the car with a 1/2" ratchet and extension up through the spring perch in the a-arm. they work just fine.
Purchased in late 2003 or early 2004. Both front and rear adjust from the top with a 1/2" ratchet. They don't race 3rd gens anymore so I don't believe they are as serious with they're offerings anymore.
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
toronto formula
Nov 10, 2015 06:17 AM
