MiniRam, TB, Injectors Etc....WHOLE TOP END
Car: 1991 Firebird Formula
Engine: 6.0 LQ4
Transmission: TKO600
Hey guys. I sold the miniram, fuelrail and injectors: I Still have 58mm professional products TB, MSD 8366 pro billet distrubutor, msd coil, TPIS level 5 ECM, comp cams xfi280. I am willing to work with you guys as you all are a great group of guys and id much rather give everyone here dibs before i put it on ebay, craigslist, or ls1tech. So please feel free to contact me by phone if neccessary or PM, my numbers 563-570-0713 and my names Cody.
PS: Im also gettin rid of the 700r4 i had rebuilt 500 miles ago sense i picked a 4l80e for 300 bucks
. Its built for 600hp and has a trans go 2-3 shift kit with a monster 3000 stall, corvette servo, etc.
Thanks guys
. Its built for 600hp and has a trans go 2-3 shift kit with a monster 3000 stall, corvette servo, etc.Thanks guys
Last edited by Cody Ashby; Aug 10, 2010 at 01:08 PM. Reason: SOLD SOME STUFF EDITED LIST
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: MiniRam, TB, Injectors Etc....WHOLE TOP END
Prices?
Engine: 6.0 LQ4
Well ill start by sayin everythings best offer. MR $700, fuel rail kit $225, TB= $200, Injectors $200, probillet dist $200, Level 5 ecm $400, xfi280 cam $200, $700 bucks with converter, or $500 w.o....Thanks guys
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: 6.0 LQ4
Its just the chip, but its wat the tune is loaded on and them put into the computer. Thanks
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
try corvetteforum.com they have a ton of TPI guys in the c4 section!
Car: 1988 Iroc Z28
just my 2 cents man the problem is your chip aint right you have an off the shelf chip that wasnt designed around the parts in your setup http://pcmforless.com/ talk with these guys i would reccomend them to anyone the so called stage chips some people sell will get you a ballpark tune with all the parameters a little off unless you built your motor exactly the same with the same parts as they did for there stage chip
Engine: 6.0 LQ4
pm sent, and yes it will work with the stock fuel rails and wiring harness. only 1500 miles on them
Engine: 6.0 LQ4
ttt, lets get this sold guys, who ever buys this stuff is getting damn near brand new stuff!
Car: 92 Z/28...many more !
Engine: LY6 / pro charger
Transmission: 4L70E 5000 stall
Axle/Gears: Moser 9" 3.89 gear
hey man i would like to buy the mini ram and fuel rails call me @ 434-277-9135 or 434-944-7383 thanks Pete
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Do you have any proof that the trans was rebuilt with the proper parts to hold 600hp? Where in Iowa are you located?
Engine: 6.0 LQ4
Im in the Quad Cities. I do have a list of parts that were installed in the tranny. If your intersted in seeing them PM me and ill get you the list. Thanks
Engine: 6.0 LQ4
Yes i have a list of parts that were installed. Im in the quad cities. PM me if you would like to discuss. Thanks
Engine: 6.0 LQ4
no but i can more then likely have ones done from my shop i use to rebuild most all my trannys..lmk
Car: 87 GTA
Engine: 385 sbc
Post or pm me a list of what was done to the tranny, also what size is the converter,,12", 10", 9"... does it have an antiballooning plate? Is it a lockup converter? 30 or 27 spline? Thanks
Engine: 6.0 LQ4
Miniram, fuelrail kit, injectors sold. Everything else still avaivable. Thanks
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
