10 Bolt posi and 4.10 gears
Car: 1989 camaro
Engine: 357 procharged
Transmission: turbo 400 with Transbrake
Axle/Gears: 342 posi
Both were bought new and have about 500 miles on them, barely past break in time. I ended up going a different route than I had planed before and now I have way too much gear for my car. They were profesionally installed and they are still in the car for now, I wanted to post the ad now before I pull them. The diff is a stock posi/ gov lock made for 28 spline axles, the gears are motive performance.
Looking to get $250 plus shipping for both.. Can take pictures if needed
Car: 1989 camaro
Re: 10 Bolt posi and 4.10 gears
They are still in the car right now so ill try to get them out tommorrow night and get pictures up. They will fit in your car but you will need to get defferent axels. You have the 26 spline in the car.
Car: 1990 Iroc Z
Engine: 355
Transmission: built 700R4
Axle/Gears: 3.73 posi
I am interested in seeing them. Do you have any pictures? I just bought 4.10's, but I still need a 28 spline posi carrier. May still consider keeping both sets of gears.
Car: 1989 camaro
Here are the pictures of the center section and ring gear. I will be taking the pinion gear out later tonight or tommorrow. they both look perfect and no uneven wear.
Car: 1990 Iroc Z
Engine: 355
Is the carrier new as well? Did I read that right? What kind is it? I can see it's not the same as the Auburn unit that just took out my R&P.
Car: 1989 camaro
Yes the center is new too I bought them at the same time. I can take more pictures if needed, just let me know...
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
