Parts left over from Parting out 1986 Z/28(most parts $10)
This what I have left:
cold start (9th) injector $10
3" Catco catalytic converter $25
stock starter (mini style. Smaller than normal starter) $10
Power steering box $25
Power steering pump $10
Fan (5 blade) w/ new clutch $10
153 tooth Flexplate $10
Ribbed pulleys (water pump and crank) $20
Air box w/ dual filters $10
Located in Hatboro,PA
Re: Parts left over from Parting out 1986 Z/28
It originally was a auto but was later converted to a stick. So to answer your question when I pulled this set up out of the car it was stick. i don't know when the manual conversion was done. The ECU could have been in the car before it was done. I did not build the car. I bought it as a parts car.
Car: Hot Wheels
Engine: Stroker 383
interested in ecu , but if it doesnt work on my app, im stuck with a ecu I cant use .would yo u consider 30.00 shipped
I don't see why it wouldn't work. Even if for some reason it didn't you could probably get that one thing changed on the chip so that would work properly and I would think it wouldn't cost that much to do. The ECU cost 389 brand new so for
50 bucks I think its worth a shot.
Car: Hot Wheels
Engine: Stroker 383
THE HARNESS PATCH SHOULD MATCH ? CAN YOU SEND PIC OF HARNESS PATCH. IF IT MATCHES, i WILL TAKE .iS THIS A MOTORVATION ECU OR A STOCK ECU REPROGRAMMED BY THEM ,iT IS THE ECU NOT JUST THE PROM
cHRIS
cHRIS
It is a Motorvation ECU custom calibrated for this set up. It was purchased from Summit Racing for 389.00. I'll take pics this afternoon when I get home.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
You got any pics of it and also how much would it be shipped to 90650
1992 Trans Am
May 10, 2023 07:19 PM
