Everything must go
Old Aug 17, 2010 | 09:51 AM
john1784h@yahoo's Avatar
Everything must go
Alright guys and gals, the car is being parted and sold.
It is a 1987 Camaro, with a 350 TPI, a 700 r4 and a Borg Warner Rear End, redone interior, performance suspension, and some extra parts. Everything must go. Ive done research on these parts and there is some wiggle room. These parts are all inspected, new or reman’d direct from manufacturer. This car was being built for a mix of street, strip and track. If you want multiple items, i can work out a deal. If you're interested in something, let me know and i can work out a price. Shipping is not included in pricing, depending on amount, i will pay or split with you if its alot. Just let me know and we'll discuss.
Full Car all parts, that includes everything on this list and then some. $6000
Engine-
from a 1989 Firebird Formula, 350ci with a tri-angle port job on stock heads, 23 lb Venom injectors, Billet Aluminum Distributor, ported TPI with airfoil, underdrive pulley set. Engine had 35,000 miles on it, idled just fine, removed from car last winter. All accessories included. New water pump, and alternator, starter, starter solenoid, plugs and wires. Wiring harness included. After rebuild was broken in using syn oil then removed from car.
($1500.00)
Transmission-
700r4 with B&M ratchet shifter, B&M torquemaster 2000 transmission was rebuilt the winter of 2006, b&m shift improvement kit installed, filled with syn fluid and yokes replaced.
($300.00)
Rear End-
9 bolt Borg Warner, pbr calipers, cross drilled and slotted rotors, I believe its the 3.27 gear ratio.
($250.00)
Exhaust-
Hooker Super Comp Headers w/ Y-Pipe (set $750)
3” Flowmaster Cat Back kit #17233 (indiv $450)
Complete Kit- ($1100)
Hoods-
1983 Z28 Fiberglass hood ($75)
1987 Berlinetta Steel Hood ($50)
Lights-
1987 rear lights(set) ($30)
1989 rear slights(set) From Firebird Formula ($30)
1987 headlights, all 4 ($30)
Interior-
D/S bucket seat-grey ($50)
P/S Bucket seat-grey ($50)
Rear bench seat- grey (both bottom and back) ($50)
Headliner-grey ($65)
Dash Pad-black-uncracked, like new, no fading or damage ($200)
Carpet-grey ($100)
Door Panels- grey ($30)--both sides
Seat Belts- all-grey ($20)
Rearview Mirror ($5)
Rearview mirror with map lights ($15)
Lower Console, with arm rest. ($100)
Body-
Full roller will include, full suspension, which is new polyurethane bushings all over, and a stage 3 "g machine" kit from performance suspension.com. Front and rear calipers are reman'd with cross drilled and slotted rotors and ebc brake pads. All doors, windows, trunk lid, rear end, lights, and fenders, and your choice of hood. ($2500)
With all interior pieces: $3000
If exterior parts are gone, $1500, gets you the rear end, and the subframe, a-pillars etc and interior parts.
No interior and external parts are gone, just subframe, rear, a-pillars etc, $275---pick up only
Wheels/Tires-
American Torque Thrust 2’s (excellent) w/ Kumho Ecsta Supra Tires (good condition) Front- P245/45zr17 Rear- P275/40zr17 ($800-full set)
OE Rally Wheels (good) w/ mix tires 15 inch (fair condition) $200
Other-
Set of T-Tops from a 1989 Pontiac Firebird Formula Lexan with keys. Seals in tact. ($50)
Full kit for 3rd gen Camaro hardtop weather stripping, from softseal. Unopened, uninstalled. ($275.00)
Fully Reversible Radiator mounted fan with new aluminum radiator. ($75)
Grant Steering Wheel, with installation kit. Bowtie center cap ($75)
Edelbrock Strut Tower Brace, never installed, box gone. ($115)
Last edited by john1784h@yahoo; Aug 17, 2010 at 09:55 AM. Reason: adding description on parts and adding new parts.
Old Aug 17, 2010 | 05:46 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Everything must go
you wouldnt happen to have fuel lines for the tpi setup would you? im in need of the settl lines for a serpentine setup, the rubber extensions, and the air intake from the TB forward to filters if youve got it
Old Aug 18, 2010 | 08:11 AM
like the fuel rails? or the rubber fuel hose? or something else?
Its a complete car, i probably have what you need.
The air inlet tube i have is from a 2.8v6, idk if that will work for you, i have it though.
Leme know exactly what you're looking for, and a shipping zip
Old Aug 19, 2010 | 08:11 PM
bump for info:
full interior is pending....
make me an offer on these parts people....ALL PRICES ARE NEGOTIABLE
Old Aug 19, 2010 | 08:23 PM
Local Sale of Covans Classic gauge panel with autometer cobalt gauges, fell through.
Retail $829.95
I'm selling for $700
Old Aug 21, 2010 | 12:18 PM
WildRidez's Avatar
Car: 96 SS, 72 SS, 06 TBSS
Wheels/Tires-
Are they 17x9 on all fours or 17x11 in the rear?
Old Aug 21, 2010 | 10:20 PM
dirtybrd88's Avatar
Car: 88 t/a tpi ported polished bolt ons
Engine: lb9 got 406 on paymnt wow FI 406
Axle/Gears: 99 z28 342 in back
id like to but the 2 hard line that run from the 2 he wants (they run behind the alt on a tpi set up and screw to the feul rails if theyre not bent up 15 shipped ? PM Me TY
Old Aug 23, 2010 | 12:27 AM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
PM sent.
Old Aug 23, 2010 | 03:29 AM
joee5's Avatar
Car: 1986 Z28, 2006 Cadillac Escalade
Engine: 5.0 litre
PM sent
Old Aug 24, 2010 | 08:09 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
You have the K&N filters for the stock airbox and possibly a headlight ****?
Old Aug 24, 2010 | 10:37 PM
firehawk1724's Avatar
Hey what's up...I'm interested in the trans...and the injectors oh and the distributor..how much sent to 48238?
Old Oct 6, 2010 | 11:13 AM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Dibs on Seat belts! maybe if I put some working ones in the girlfriend will want to ride in the car
Old Oct 6, 2010 | 11:21 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I wouldn't hold my breath if I were you lol my wife still won't ride in my camaro because its "not safe" aka I didn't buy a new car before fixing mine lol she complained about the seatbelt holder on the seat being loose, so I fixed it and still not good enough lol they've always got an excuse now her go to is "the exhaust smells like gas" well yeah when you're standing right behind them and its coming at you, you're gonna smell it that's why they point back you don't smell it in the car lol
Old Oct 6, 2010 | 01:24 PM
Brendan91Z's Avatar
Car: 1991 Camaro RS, 2013 Camaro SS 1LE
Axle/Gears: Stock
I wish I could pick up the rear end.. unfortunately I'm in Cali.. How much would you do the rear end shipped to 91387? Also its disc right just checking. And is it complete so I can just drop mine out and put it in?
Old Oct 6, 2010 | 04:17 PM
gunnink's Avatar
Car: 1988 Iroc T-Tops
Engine: 5.7 TPI
Axle/Gears: 2.77
Any way to send me a pic of the door panels? Also are seat belts original equipment and what are their condition? Dash pad also? Will these all fit a 88 Iroc? Interested in all these parts if in prestine condition. Thanks!
Old Oct 6, 2010 | 04:25 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I may have missed this, but is it a T-Top car?
Old Oct 6, 2010 | 04:47 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Probably a stupid question but Will that 9 bolt hold up to an ls1? I can pick up cash in hand, I'm near six flags
Old Oct 7, 2010 | 11:18 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
picture of steering wheel; timinsk@gmail.com
Old Oct 8, 2010 | 08:37 AM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Transmission: 700R4 Auto
Axle/Gears: G92
still have the rear end and trans?
Old Oct 8, 2010 | 10:37 AM
ademarti's Avatar
please let me know hat is included in the weatherstripping kit and your best price
Old Oct 10, 2010 | 08:19 PM
thewizard's Avatar
Looking for headlight ****, oil pressure fitting from top rear of block, and Accel ignition module.
Old Oct 15, 2010 | 05:48 PM
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
Got a price on the megashifter?
Old Oct 15, 2010 | 08:41 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
PM sent
Old Oct 22, 2010 | 08:13 AM
rabblerouser's Avatar
where in south jersey? interested in the trans setup
Old Oct 22, 2010 | 10:06 AM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Axle/Gears: 3.27 9-Bolt
Rear still complete and available?
