[OK] Turbo TTA and Buick GN Engine parts
Old Aug 26, 2010 | 10:28 PM
MPIpowered4x4's Avatar
For sale:
ARP head studs, Non-Stage block, Used $50 Pending Sale
ARP Rod Bolts, Unused, $40 Pending Sale
'148 86-87 ECM, No Chip, $40
Kenne Bell Regulator, with Fuel Rail $60
MSD 50lb injectors, and Joe Lebrant Chip for 93 Octane $175
Stock 86/87 Upper and Lower intake, bead blasted, unported $150
Stock 86/87 Turbo, Some shaft play, no bent fins, complete minus inlet bell, $75
New TRW Single Roller timing chain for use without tensioner $25
Pass side 86/87 Header, Jet Hot coated, great shape $100
8445 Heads, back from the machine shop, 3 angle valve job, new seals and Comp 980 springs. Unported. $150 Pending Sale
84/85 Turbo Block, Stock bore, honed, back from the machine shop, new freeze plugs and cam bearings. $150
Stock turbo crankshaft, STD/STD, journals are in great shape, SOLD
Stock 2 dot rods, with stock pistons, great shape, $50
20 bolt timing cover, bought from intercooled88ss, $30 Pending Sale
Turbo Riv Wiring harness, could use some repair, $30
Regal 3.8l frame pads, $15
Erson 214/214 flat tappet cam, with lifters, packaged individually so they can get put back in the exact same spot. SOLD
Buick Engine to Chevy Transmission adapter, Brand new. $40
I can get pics of everything. Prices are plus shipping. PM me, or call me 405-532-9470
Old Aug 27, 2010 | 02:48 PM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Re: Turbo TTA and Buick GN Engine parts
Will you sell just the lower intake? If so, PM me a price shipped to 92592
TIA
Old Aug 27, 2010 | 02:51 PM
TIA
I will hook you up, I will give you the upper, for $165 shipped. Let me know, you are not the first PM.
Need some injectors and chip?.
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
lee01
Apr 9, 2016 01:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
