[CT] Garage Clean-Out, Cheap Parts!!!
Car: '89 IROC-Z
Engine: LSx
COMP cams 12-256-4 XE256 flat tappet cam with lifters. http://www.summitracing.com/parts/CCA-12-256-4/ Broken in with COMP break in additive, barely even saw 3,000 miles before I tore the motor down and changed set ups - SOLD!!!!!!!!!!!!
86 TPI runners with 9th injector block off plate - $25 Shipped
89 LB9 19lb/hr fuel injectors, came off my old 305 - $20 Shipped
Factory serpentine water-pump, spins freely and never had issues - $30 Shipped
89 Steel driveshaft, a little rusty but never vibrated, would replace the u-joints - $40 Shipped
Stock LB9 exhaust manifolds with air tubes cut off and filled, never leaked, also have new gaskets - $30 Shipped
Factory external ignition coil off my 89 - $10 Shipped
Mallory 8mm plug wires, strait plug ends with 90* coil ends, set up to clear manifolds and be run through moroso wire guides, I have a pick of the set-up, barely used - $30 Shipped
All prices are OBO to a reasonable extent. I have pics of everything upon request. Your best bet is to either PM me or email me at LittleCapone2291@aim.com Thanks.
Car: '89 IROC-Z
Engine: LSx
Re: Garage Clean-Out, Cheap Parts!!!
Also have a brand new set of 8 AC Delco R45's, http://www.summitracing.com/parts/ACF-R45TS/. Got them for my 355 and realized I needed shorty plugs almost all the way around - $15 Shipped
Car: 87 Iroc
Engine: 5.7L 350 HSR
Do you have a distributor? Preferably aftermarket? If so, would be interested in the wires and plugs too. If not, how much for the wires and plugs? Shipped to APO AE 09139?
Car: '89 IROC-Z
Engine: LSx
PM's sent, chris I'll pm you if the wires dont sell. Make offers on the rest of the stuff!!
Car: '89 IROC-Z
Engine: LSx
Car: '89 IROC-Z
Engine: LSx
LT1Formula
20
Nov 14, 2015 12:02 AM
Street Lethal
Aug 12, 2015 11:33 AM
