[CT] FS GM Fastburn Heads
Re: FS GM Fastburn Heads
may be interested...pics & details please??
I will get some up this afternoon after work.
Here are the specs straight from GMPP
Dave
Part #12464298
Aluminum Fast Burn Cylinder Head Assembly
CNC-machined aluminum performance head
Completely assembled with 2.00/1.55 valves
210cc intake port, roof raised .240
78cc D-shaped exhaust ports, raised .200, requires Fel-Pro' gasket #1470 (may require minor trimming)
62cc combustion chamber, .400 thick deck (can be milled safely .060)
No heat riser
Angled spark plugs (5/8 hex, 3/4 reach, tapered plugs)
1.48 Valve spring seat diameter
Use head gaskets with stainless steel fire rings
Raised, machined rocker rails
0.530 max valve lift (without modifications)
Screw-in studs, (3/8 top, 7/16 bottom)
Dual bolt patterns for perimeter bolt and center-bolt valve covers
Dual bolt patterns for both Vortec and early model intake manifolds
Use production intake gasket P/N 12529094 for Vortec intakes or dual bolt pattern intake gasket P/N 12497760 for either early model or Vortec design manifolds (Fel-Pro' #1289 and #1207 may be used)
This head is assembled with the following components:
12555331 Intake Valves
10212808 Valve Spring Retainers
12551313 Exhaust Valves
10212810 Valve Stem Seals
12551483 Valve Springs
10212809 Valve Spring Shims
12552126 3/8 Rocker Studs
24503856 Valve Locks
Dave
Part #12464298
No heat riser
Yes they are brand new never been installed worked on ground on etc. In the pics I sent the reason for the various views so each side can be seen on both of them.
Did I get offers? What does that have to do with anything? The answer is yes but in the end thier wife girlfriend whoever did not give them the ok to buy and yes it was at the asking price that was not a problem. I bought them for my C4 Corvette with the plan of shooting for around 425 at the crank then got thinking I really do not have the energy and ambition to update the Dana 36 transmission converter etc.. Don't have a real need to sell them money wise but need them less than I did when I bought them.
These are going for around 1450 to 1500 a pair for exactly what I am asking 1000.00 both never been used.
Let me know if you are interested.
Dave
Dave
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
700 if I pick em up?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
