[LA] HSR, painless speed density harness, 42lb injectors, autoprom, BBK TB
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Hi, I have a HSR set up for speed density, will all but the Knock sensor for sale. It has 42LB injectors, BBK TB, Distributor, Coil, painless wire harness, computer autoprom. I would like to get about 900 for the everything but im open to offers, or will trade for a weiand 142 blower. I will consider breaking it up if it doesnt sell. Thanks.
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: HSR, painless speed density harness, 42lb injectors, autoprom, BBK TB
If you decide to part it out let me know what you would want for the 42# injectors
Car: 89 z
Engine: 96 350 HSR vortec
Transmission: 700R4 24-2800 BDR stall
Axle/Gears: 9 bolt disc posi w/3.45
How much for the lower part of the HSR.32935
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
what do you mean lower intake, with or without fuel rails?
Car: 89 z
No fuel rails nothing with it just the lower half.It is for an 85 or earlier bolt pattern right.
please confirm or deny, is this a COMPLETE system to convert to MPFI minus the knock sensor? if it is, I'll seriously take it asap and ship to 23229.
I'm not familiar with "autoprom" or whatever that USB connected device is. what are these components?
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
yes, it is a complete system minus the knock sensor. The knock sensor depends on if you are using a 350 or a 305, they use different sensors. The autoprom is what you need to burn chips, and datalog.
really..... that's intersting. so, the autoprom is what.... a piece of hardware that connects to the pc so I can take the PROM out of the PCM I either currently have, or what comes with your kit, and install it in this device and can apply a tune?
Honestly, I'm pretty interested. those are some pretty fat injectors. I'd like to run some AFR 210s with a 383 setup, so they may be what I need, and the HSR is something I absolutely desire. I purchased a complete TPI system, only to realize that it would cost so much to modify (intake, injectors and tune) that I could buy a stand alone system like this for the same cost.
how did you go about piecing this together? it seems a little unusual
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
yea, the auto prom lets your burn the new chips, or you can use it to do real time simulation, acting as a PROM until you get the tune you like. The injectors are a little large, I was going to use it with a Supercharger, but If you plan to spray, or supercharge then its good, You can always sell them and down grade, but my car ran well on them without any power adders. I actually have AFR 210 and the intake has some porting but not too much because there isnt much meat to port.
i just did a slight bit of youtube research on the autoprom. it looks like a useful device. do you have a complete ECU/PROM setup for this installation, or were you running it completely in emulation mode through a laptop?
also, what size TB is that? 52, 58, ect?
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
I used the factory computer with the adapter to allow me to use burned chips, or the autoprom for a real time. The TB is 58mm. Its by BBK and they are like 319 new.
well sir, I would like this setup for my car, but honestly 900 is gonna be a bit of a push at the minute, and shipping is always a pain. if you're interested, i can do 800 shipped, I can pay you immediately via paypal if you'd accept that offer
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Can you do 850 shipped. Shipping and the paypal fee should be about 50.
I accept paypal camarojokester@yahoo.com
Navy8125
Aug 22, 2015 07:13 PM
