[NJ] Complete TPI Setup. Tpi dual fans. Tpi airbox
Old Nov 3, 2010 | 12:08 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
Tpi intake set up $150obo
Dual fans $30 plus shipping
Tpi airbox $30 rather not ship
Can deliver or meet nj ny pa area.
Tpi set up off 87 IROCZ 60k INCLUDES
TPI Plenum/Base/Runners/throttle body/thermostat housing
NEW 19lb Injectors (FIC)
NEW Coil
NEW Fuel pressure reg
NEW Ignition module
NEW Coolant temp sensor
Complete Distributer
Fuel rail
MAF sensor
Egr and block off plate on there now
9th Injector
All Sensors MAT/ TPS/ IAC mtr
MAF Relays
ESC Module
Old ignition module included still good
And wire harness cut at blower motor but the fan wiring, ac wiring and egr control wiring are removed. Pretty much all bolts and brackets are there just needs to be cleaned up and new gaskets. All the new parts have been installed within last 500miles and decided to go carb. Would consider shipping but problay wont be cheap its all fairly heavy. Can meet within 2hrs of Manahawkin NJ 08050.
Old Nov 3, 2010 | 05:19 PM
Project84TA's Avatar
Car: 85 Camaro IROC, 88 K-1500
Engine: 357 TPI, 350TBI
Transmission: T-5, NV3500
Axle/Gears: 3.42 posi, 3.73 i believe
Re: Complete TPI Setup. Tpi dual fans. Tpi airbox
if you would be interested in separating the intake setup i'm just looking for the coil bracket.
thanks
joe
Old Nov 5, 2010 | 10:22 AM
zen2's Avatar
Car: 49 chevy
Engine: 94 305
Pm sent on the intake.
Old Nov 6, 2010 | 09:05 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Can you include the upper mount radiator holder with the fans?
Old Nov 7, 2010 | 01:42 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
PMs replied.
I cant include upper rad mount i modified it and it was reused.
Old Nov 11, 2010 | 11:05 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
BUMP
Fans and Airbox sales pending
Old Nov 26, 2010 | 06:15 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Bump
Fans Airbosx SOLD
Old Nov 29, 2010 | 04:47 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Still have MAF sensor?
kevin
Old Nov 30, 2010 | 12:27 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
You've been PM'd
Old Dec 31, 2010 | 10:45 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
BUMP still have TPI SETUP
Old Jan 2, 2011 | 10:54 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
BUMP
Old Jan 16, 2011 | 11:01 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
bumpp
Terrell351
Jun 13, 2021 01:13 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
KO1
Aug 31, 2015 06:31 PM
Sanjay
Aug 12, 2015 03:41 PM
