wanted sbc roller mechanical camshaft/lifters
Old Dec 15, 2010 | 12:11 PM
snowboardgod869's Avatar
Car: 1991 RS Camaro
Axle/Gears: 9 bolt 3.27
im looking for a used or new sbc roller mechanical camshaft and lifters and valve springs and rockers if you have them but mostly lookin for the camshaft and lifters but i am looking for a cam with above .500 lift and below .600 but must be a roller mechanical camshaft no hydraulics
Old Dec 15, 2010 | 12:12 PM
Car: 1991 RS Camaro
Re: wanted sbc roller mechanical camshaft/lifters
it must also be for an 86 and older block and i dont really want to retro fit any newer parts in it
Old Dec 15, 2010 | 05:13 PM
crackitoff's Avatar
Engine: Shafiroff 434
Transmission: Jake's Performance Stage 4 TH400
Axle/Gears: Strange S60/spool w/ 3.73's
hey snowboard.....i have a brand new lloyd elliot solid roller cam for sale on the board under "3rd gen blowout sale". my buddy is selling it for me.....duration is 255/263 and lift is 626/626 on a 114 LSA. it's a small base circle cam i was going to put in my 434 smallblock but went a different route. i know you said you wanted to stay at .600 or below but i just thought you might be interested in it. let me know or let my buddy who posted it up know. the cam is located in virginia. by the way it's for a non roller block like you said you needed.
ern
Old Dec 15, 2010 | 09:36 PM
Car: 1991 RS Camaro
i might be interested im building a 350 sbc bored .40 over with 1964 to 1966 2.02 double hump heads but would i have any clearance issues with that high of a lift cam? cause i dont really want to spend the money to blue print my engine and is that a good name camshaft or is it some thing thats a little bit cheaper and how much would you want for it and do you have any lifters to include with it?
Old Dec 16, 2010 | 05:17 AM
crackitoff's Avatar
you should have no clearence issues if you do it right. you will need at least 11 to 11.5 comp. ratio, scew in rocker studs, valve springs, guide plates, and the right pushrods and you should have no problems. i'm not sure if your heads will flow the numbers needed for this cam to work correctly. i'm guessing you have an engine builder doing the machine work...ask him if this cam will work for your setup and see what he says.
lloyd elliot is a very reputable cam designer...from what i'm told he's one of the best. talk to your engine guy and let me know. i think my buddy has it posted for $260 shipped. the cam was $320 when i bought it new. no lifters just the cam.
ern
Old Dec 16, 2010 | 06:05 PM
DanZ51's Avatar
Car: '86 Vette
Axle/Gears: 4.11
I have a set of Crane solid roller lifters I bought used off a member of the Corvette Forum who was upgrading to offsett lifters. I never got a chance to use them, as I changed to a later block.
Still have them, been sitting in oil since I bought them three years ago.
I'll sell them for $100 plus the ride (I paid $150).
Old Dec 16, 2010 | 09:16 PM
Car: 1991 RS Camaro
i might be interested depending on how used they are because the lifters ware to the lobe of the camshaft you said they were used? and could i get some pictures do they look pretty new or?
Old Dec 17, 2010 | 05:55 PM
DanZ51's Avatar
Car: '86 Vette
Axle/Gears: 4.11
I'll see if I got a working camera and post up some pix. They're used but show no wear makes. They guy I got them from was pretty reputable (he wouldn't sell me worn out junk).
Old Dec 17, 2010 | 10:42 PM
Car: 1991 RS Camaro
ok get me thouse pictures and e mail them to me at snowboardgod869@yahoo.com and there soild mechanical roller lifters right?
Old Dec 25, 2010 | 03:55 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
i have a brand new set of springs for a solid roller cam they are for a cam with Just under 600 lift and over 550 lift 1.44 wide (crane) new in box
have all the info on the cam card (springs are new in the box)
also have a set of solid roller lifters comp cams close to new
you can have this set $155 shipped springs and lifters
paypal is ok
Old Dec 25, 2010 | 07:59 PM
mesterious's Avatar
If you haven't bought a solid roller cam yet I have one that sound's exactly like what you are looking for. Here is the link to it https://www.thirdgen.org/forums/engi...doo-solid.html
Old Dec 26, 2010 | 10:58 PM
Car: 1991 RS Camaro
articwhite you just have springs and lifters right no cam for sale? and mesterious i might be interested in your camshaft let me talk to my engine builder and see what he thinks of it i dont exactly have a set of rear end gears to support the camshaft but ide still be interested im running a 9 bolt borgwarner rear end with 3.27 posi gears and the website for your camshaft says you need 3.90 or better but i might not care ha ha
Old Dec 26, 2010 | 11:31 PM
mesterious's Avatar
ha sounds good to me! Just send me a message when you find out some information. Thanks man.
Old Dec 27, 2010 | 04:42 AM
for $50 more you can have a milodon 7 QT oil pan (gold Zink plate) pasngr side dip stick 2 pc rear main (if you can use it) w melling HV oil pump and milodon pick up for the pan..(but for that $10 shipping ill cover te rest)
Old Dec 27, 2010 | 06:02 AM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
roller lifters do not wear to the cam and the cam dosent wear either. they are billett steel wich is why with most u have to use a bronze dist gear. they only way a cam is gona wear is u break a roller.
Old Dec 27, 2010 | 06:03 AM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
what springs at 1.440 have 240psi on the seat? curious if they do i may be interested.
Old Dec 27, 2010 | 06:04 AM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
u got any pics if u still have these i could use a set.
midge54
Dec 27, 2019 04:14 PM
gta90
Sep 15, 2015 04:00 PM
R3500
Aug 17, 2015 12:16 PM
sreZ28
Aug 14, 2015 07:48 PM
BrianI
Aug 9, 2015 11:52 AM
