[Sold] stock 350 TPI ECM Chip
Old Jan 9, 2011 | 05:47 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
used stock 350 TPI ECM chip from 87 firebird, replaced it with moates tuning stuff for 383 combo, worked fine before replacing. A must if your swapping a 350TPI in from a 305.
40$ plus 5$ shipping to continental USA
Old Jan 15, 2011 | 06:14 PM
Car: 87 TA clone
Re: stock 350 TPI ECM Chip
bump
Old Jan 15, 2011 | 07:07 PM
Datsun570Z's Avatar
Will this work for a 93 lt1?
Old Jan 16, 2011 | 04:37 PM
Car: 87 TA clone
nope. just 85-92 TPI
Old Jan 28, 2011 | 08:33 PM
Car: 87 TA clone
bump!
Old Jan 29, 2011 | 08:41 PM
jbzr1's Avatar
Want a title? Post!
Car: 89 Corvette
Transmission: 700 auto
Axle/Gears: 3.08
PM sent
Old Jan 30, 2011 | 07:51 PM
Car: 87 TA clone
bump
Old Jan 30, 2011 | 08:56 PM
brose's Avatar
Car: 87 iroc
Engine: 358 tpi
Transmission: 5spd
Axle/Gears: 3.42s
how much?
Old Jan 30, 2011 | 08:59 PM
Car: 87 TA clone
price is in the first post. 40$ plus 5$ shipping to continental USA. i have a few ppl interested but im waiting to hear back at the moment.
Old Jan 30, 2011 | 09:08 PM
brose's Avatar
Car: 87 iroc
Engine: 358 tpi
Transmission: 5spd
Axle/Gears: 3.42s
sorry i meant that message to say ecm chip. i no ur selling just the prom and im interested if it will work
Old Jan 30, 2011 | 09:50 PM
Car: 87 TA clone
From what i know the 165 ECM (MAF ECM) is the same from 85-89 then they discontinued the cold start injector, otherwise the ECM is the same except for the VATS system (vehicle anti theft system) the only difference between the 305 and the 350 is the "tune" and the injector sizing. The tunes are totally different, i know bc i looked at the stock tunes with my moates hardware, the MAF tables are different due to different displacements, different timing due to different cams, injector size is different (305 has 19lb injectors and 350s have 22lb injectors) so basically throwing in a 350 in the place of a 305 wont work, dont get me wrong it will run, but it will run PIG rich and run like poo. If your car was originally a MAF car before 89, and you had a 305 and swapped in a 350 (including 350 injectors) then the chip should fix your issue.
Old Feb 2, 2011 | 10:50 AM
Car: 87 TA clone
SOLD!
camaro71633
Sep 1, 2015 10:24 AM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
BOOT77
Aug 10, 2015 12:20 PM
