NEW 3.73's for 10bolt
Old Feb 21, 2011 | 04:42 PM
Pab's's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI with zz4 heads
Axle/Gears: 9 bolt BW
I have a set of New 3.42's for the 10 bolt $150
Old Feb 21, 2011 | 11:20 PM
Pab's's Avatar
Car: 1988 IROC-Z
Re: NEW 3.73's for 10bolt
any takers OBO anything
Old Feb 22, 2011 | 06:50 PM
peepsrs's Avatar
Car: 91 Rs
Engine: 383 hydrolic roller carb
what brand and what series carrier r they for
Old Feb 22, 2011 | 11:20 PM
Pab's's Avatar
Car: 1988 IROC-Z
motive and for the 7.5 10 bolt
Old Feb 23, 2011 | 06:03 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
peepsrs is referring to the series carrier, not the housing Pab's. Series 2 or 3?
Old Feb 23, 2011 | 11:03 PM
Pab's's Avatar
Car: 1988 IROC-Z
Old Feb 24, 2011 | 08:05 AM
peepsrs's Avatar
Car: 91 Rs
Thank you. I need a set for a 3 series.
Old Feb 27, 2011 | 04:57 PM
1Broke_camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
sorry for sounding dumb but whats the difference from a 2 or 3 series carrier? how can i tell? is it the abs setup?
Old Apr 12, 2011 | 11:03 PM
wakeboardr42393's Avatar
Car: 1987 BMW 325is
Engine: M20B25
Transmission: Getrag 260
Axle/Gears: 3.73 LSD
i thin ki read an article or pise somewhere about this. im pretty sure it goes something like this: one of the "series" carriers is the style that was used from the factory for gear ratios < 3.23 and the other was used for 3.23 and greater. im pretty sure its something like that. could be wrong, but i thought i remembered something about it.
also, would you be willing to part out your rear?
Old Apr 13, 2011 | 09:19 PM
peepsrs's Avatar
Car: 91 Rs
I ended up buying a ford 9inch off of here so I have my 10 bolt that has all other parts minus the gears...what are you looking for
Old Apr 14, 2011 | 02:50 PM
blakecharles's Avatar
bump!!
is this still for sale? what's the model#?
Old Apr 14, 2011 | 10:09 PM
Car: 1987 BMW 325is
Engine: M20B25
if it is a series 3 i would buy it. series 2 not so sure about, unless i can find a spacer (planning on getting junkyard gears)
i would like the carrier, are you sure its a series 2?
heres another post about this same topic: https://www.thirdgen.org/forums/tran...i-carrier.html
Old Apr 14, 2011 | 10:42 PM
peepsrs's Avatar
Car: 91 Rs
my carrier is an auburn 3 series carrier that I had richmond 3.73 gears on and I broke the gears but the unit is still good. I think $175 plus shipping is fair
Old Apr 15, 2011 | 04:18 AM
Pab's's Avatar
Car: 1988 IROC-Z
Yes its still up for grab's they are 3.42's I checked them out I thought I had 3.73's but i must have gotten the wrong ****. So not sure what series carrier their for
here's the part number
GM14085338-13:42-7 5/8
UltRoadWarrior9
Apr 28, 2020 10:39 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
JSDaddy189
Sep 26, 2015 03:50 PM
whyt86roc
Sep 10, 2015 10:03 PM
