[NJ] TPI throttle body linkage convert TPI TB's to LT1 and TPI
Old Feb 28, 2011 | 09:48 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
I have 2 leftover throttle linkages that allow you to adapt the TPI throttle body for 85-88 TPIs with a 305/350, 89-92 TPIs with a 305/350, as well as has a sleeve to convert our TPI throttle body to work with an LT1 from 92-93 as well as LT1s on 92-96 corvettes.
Please see pic to what im talking about, purchase will include hardware for the IAC to TB mounting as well as the instructions for the throttle body linkage and TBs.
price: 30$ plus 5$ shipping to 48 states continental USA.
Attached Thumbnails TPI throttle body linkage convert TPI TB's to LT1 and TPI-589.jpg
Old Feb 28, 2011 | 10:53 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Re: TPI throttle body linkage convert TPI TB's to LT1 and TPI
I'm kinda confused, I think LOL My TB is an 85-88, but my car is a 91 Z/28, are they so I can convert the 85-88 linkage to a 89-92 linkage?? If so I might be interested...or are they just to convert to LT1?
Old Mar 1, 2011 | 12:13 AM
Car: 87 TA clone
From what the instructions say... ill try to break it down for you.
this 58mm TB comes with extra throttle linkages for different setups for different engines since factory engines dont come with all the same linkages. ( basically they had to give you all the throttle linkages for the years of 85-96 since those years they all used the same universal TB. However the linkages changed from 85-88, 89-92 and then of course the Lt1s are different). So from what i understand is that this has the linkages for a 85-92 TPI and then has the extra "sleeve" to convert tho the newer Lt1 throttle cables/linkages.
So in the pic you can kinda read the instructions (images with text on them) and u can read that the linkage at the bottom of the pic is for a 85-88 TPI, the 89-92 has a curved part on the throttle linkage and then the "sleeve" is added to the linkage to adapt the TB to an LT1 setup. This is bc the TB is the same from the LT1 and TPI they just changed the linkage.
This is what is left over from the 58mm TB that i purchased and is part of the kit.
Old Mar 1, 2011 | 09:42 AM
Car: 1991 red Z/28
OK, thanks! I guess it wont work for me then.
Old Mar 1, 2011 | 06:56 PM
Car: 87 TA clone
You might be able to actually! Ill take a look when im home tomarrow and look at the brackets and instructions for you
Old Mar 1, 2011 | 07:51 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
They only works on aftermarket TB's that have the removable linkage ;possibly only on the PP TB's
Stock linkage is peened on shaft ;
requires grinding head of butterfly shaft off and re welding to fit a alternative linkage
Old Mar 1, 2011 | 08:09 PM
Car: 87 TA clone
i thought that was a given?
lol. But you could still adapt a stock type TB for a different engine. welding the throttle linkage on isnt hard, just a couple of tac welds.
Old Mar 2, 2011 | 09:35 PM
Car: 1991 red Z/28
I think I'll pass on this. Thanks for taking your time to look.
Old Mar 2, 2011 | 09:43 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
i thought that was a given?.
Not to most people as indicated by the above response.
The fact you are including the instructions would make someone who doesn't know any better think
that if was a bolt on swap.
Old Mar 2, 2011 | 09:46 PM
Car: 87 TA clone
ok thanks for your interest.
i included the instructions so they could see the difference between the TPI and Lt1 throttle linkage so they knew what they had and or knew what they needed.
Anyways... BUMP!
Old Mar 6, 2011 | 02:55 PM
Car: 87 TA clone
bump
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
lakeffect2
Aug 23, 2015 08:44 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
