[MD] Ross Racing Forged Pistons NIB
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
$450 plus shipping. firm on price.
paid 550 for them, 561 through summit now
Brand Ross Pistons
Manufacturer's Part Number 90755
Part Type Pistons
Product Line Ross Racing Forged Pistons
Summit Racing Part Number ROS-90755
Bore (in) 4.030 in.
Bore (mm) 102.362mm
Piston Style Flat top, with two valve reliefs
Piston Material Forged aluminum
Compression Distance (in) 1.433 in.
Piston Head Volume (cc) +4.00cc
Wrist Pin Style Press-fit or floating
Pin Diameter (in) 0.927 in.
Piston Ring Thickness 1/16 in. x 1/16 in. x 3/16 in.
Tool Stroker Combinations
Brand Ross Pistons
Part Type Pistons
Bore (in) 4.030 in.
Bore (mm) 102.362mm
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: Ross Racing Forged Pistons NIB
just curious why you're selling these.....they're darn good pistons.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
i have an lsx and these would take too much to mod to make work so... ive had these for ~6 years, probably longer and have listed them several times with no takers.. still in the original box, all the spirolocks are there, still wrapped in the paper, etc.
hopefully youre building a motor these would be great for it
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If the compression distance is indeed 1.433, then they must be for a long rod motor...yes?
Car: 1995 Formula
Engine: LT1 350
I'm using 6" rods.
I don't think these would work for my 383 stroker build.
I still don't fully understand the difference between stroker pistons and regular pistons. Skirts perhaps?
The difference is where the wrist pin is located.
The compression distance is the measurement from the centerline of the wrist pin to the top of the piston.
For a long rod motor the pin has to be higher up. For a stroker, higher yet.
For a 355 5.7 rod, the distance should be 1.560-1.565.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
heres wht summit has to say:
Make CHEVROLET
Engine Type V8
Liter 5.7
CID 350
Engine Size 5.7L/350
Beginning Year 1967
Ending Year 2002
Engine Family Chevy small block Gen I
Rod Length 5.700 in.
Stroke 3.750 in.
Application Notes 9.025 inch block height. Designed for 22-23 degree, 0.060-0.040 inch split or Vortec cylinder heads. Suitable for up to 250 horsepower nitrous or 8.5 psi of boost.
Car: 1995 Formula
Engine: LT1 350
Yep, learn something new every day. I'm going with Mahle flat tops for my 383, if I can ever pay for the darn things.....just the pistons are needed, then my builder can finish my short block.......FINALLY.
Notice the stroke size (3.750) these are indeed 383 pistons with a 5.7 rod. (not the best combo) IMO. That's why the 1.433 compression distance.
Car: 1995 Formula
Engine: LT1 350
I know that Ross makes really good pistons.
Yep, I was told by my engine builder that I should use 6" rods for a 383. I don't know why 6" rods are better, but I went with what he said and got 6" forged Compstars.
What I don't get is why there are so many 5.7" stroker combos and pistons out there, when 6" rods are supposed to be better. Why is this I wonder?
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Read
http://www.iskycams.com/techtips.php#2005
http://www.iskycams.com/ART/techinfo/ncrank1.pdf
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Is a very academic argument
Read
Read
bump for long rod 355 pistons/ stock rod 383 pistons
Car: 1995 Formula
Engine: LT1 350
Bump for some nice pistons. SOMEONE could use these I am sure. Did you try craigslist?
Actually I was wrong. I still also need a zero balanced flywheel, for my guy to finish my short block.
And the Mahle pistons I'm getting come with rings
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
i kid... maybe. thanks for the kind words. and yes i have, no bites. ive nailed down that they CAN be used in a long rod 355 or a 5.7 rod 383 so thats where im at now.
i would use these in my 6.0 but unfortunately, that cant happen
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
1433, 1565, 355, 383, 400, 57, 90755, block, compression, craigslist, difference, distance, forged, pistons, pistons90755, racing, rods, ross, rossraceingengenscom, small
