Moser Engineering Ford 9” Housing and Axles for Thirdgen Fbody
Old Apr 17, 2011 | 10:27 AM
1992rallysport's Avatar
Car: 1992 Camaro RS
Engine: Head Cam LS1
Transmission: T56'er
Axle/Gears: 4:10'ers
I have a Moser Engineering ford 9 inch Housing for the third gen F-body. It has
Massive 35 Spline axles
Screwed in wheel studs
Date on the axles are 01-31-08
Chevy bolt pattern
Big new style ford Bearing ends
It is the newer housing with 3” axle tubes
The housing is 56 ¼ housing flange to housing flange
Has torque arm bracket
Disc Brake Brackets for the old school Chevy calipers
I am including a Strange 35 Spline strange spool, pretty much add your center case and gears and you are ready to go drag racing. I am selling this due to the limited availably of posi’s for the 35 spline axles, my car is an 100 percent street car, so a spool or locker is out of the question for my 6 speed car. The housing is very clean inside, the gear oil look brand new when I pulled it apart, housing has some scathes and light rust.
Located in Grand Rapids, MI Asking $900.00 with spool, axles, housing, brake brackets, calipers. Will help with delivery, would like to try to keep it locally.
Old Apr 17, 2011 | 03:10 PM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Re: Moser Engineering Ford 9” Housing and Axles for Thirdgen Fbody
pm sent
Old Apr 24, 2011 | 01:48 PM
Car: 1992 Camaro RS
SOLD!!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
