[IL] 350 TPI Engine for sale
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
1990 Speed Density 350 TPI with ~102k Miles. It made 211 RWHP and 313 RWTQ on a Chassis Dynojet before I pulled it. It's been sitting on the stand for a few years now. It ran good prior to being swapped for my 383. It did need new valve stem seals since there was a minor smoke puff on startup after it sat for awhile and it has the AC side bracket bolt broke off in the head. I haven't ever tried to tap it or extract it. It would get ~18 MPG average. It has Accel fuel injectors and a TPIS air foil installed. Internally it's all original to my knowledge. I've owned the car since 65k Miles. It also has the Corvette metal distributor extension cover instead of the plastic cover. Oil cooler lines are still attached. Fuel lines have been covered and taped off so there should not be debris in there. Upper clamshell mounts still attached. I might be able to find the used lower mounts and body mounted oil cooling lines for you if requested. No wiring harness, ECM, Brackets, or Accessories included. I might be able to find the stock water pump but no promises.
$400 AS-IS you haul it. I'm not crating and shipping it. Located in New Boston, IL 61272. ~45 minutes South/SouthWest of the Quad Cities near Iowa Border.
I would consider parting it eventually if there is no interest.
Car: 88 IROC-Z
Transmission: 700R4-currently being mildly built
Axle/Gears: stock 2.73:( with limited slip
Re: [IL] 350 TPI Engine for sale
damn. I'd get it If I was closer...I'm in st. louis though-200 miles
The_Phoenix
09-03-2015 10:56 PM
R3500
08-17-2015 12:16 PM
