[MI] 498 ala cart
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
498 ala cart
289 casting 454 4 bolt main, decked, line honed, 4.320 bore, filled to water pump holes with hard block.
*uses two #5 cam bearings. screens installed some small oil system modifications. valley painted.
Kb Forged pistons 47cc dome, smoothed and clearenced. 1/16 1/16 3/16 1st ring down .375
childs and alkerly HTD extreme rings (high tensile ductile iron top, naiper reverse twist , 18# oil rings)
*gapped for 450hp of no2
*pistons .015 above deck
*felpro MLS 4.370 x .053 Head gaskets
arp head studs* not incl with short blk*
Eagle connecting rods 3d h beam with arp 2000 6.385 length
Eagle 4140 ext balance 4.250 stroke std rods, .010 mains
sfi fluid dampner, sfi flex plate
*8 passes since freshened
$1600 for above
bullet cams, 4-7 swap 278/288@ 050 .775 .770 w/1.8 112 C/L
cloyes 9 way billet roller, needs .005 or .010 under set
*chain loose
.100 intake piston to valve
.130 exhaust piston to valve
comp cams 819 .842 cut away roller lifters
ADD 500.
$2100 for everything above here
Hamburg 2 part timming cover
ati timing pointer
arp balancer bolt with 1/2 socket drive
moroso 21047 7 qt steel pan, kickout, acumulator,windage tray and main partitions
arp oil pan studs
m77hv with fabbed pick up
arp main studs
ADD 600
$2700 for everything above here
Afr 325 magnum heads port matched to 1275felpro 118cc chambers 2.30/1.88 steel Rev valves, 1.625
.800 lift palcoy howards springs, titanium retainers, postive seals,manley spring cups, comp cams 10 degree locks
afr guide plates. trend .135 wall pushrods double tapered 3/8 dia. Harland sharp aluminum 1.8 rockers, afr posi locks for stud girdle.
afr stud girdles. *15 passes since freshen/valve job and new parts by douglas porting/ C performance engines
sheet metal aluminum hi clearence valve covers (ansen) with breather holes.
ADD 3325
$6025 for everything above here
Dart 4500 intake, heavy plenum porting by ronnie sharp, drilled/tapped for fogger nozzels *uses 1275-5 felpro int gasket.
arp int bolts. GM intake valley windage/heat tray.
ADD 250
$6275 for above
located near detroit mi
$1600 for above
*chain loose
ADD 500.
ati timing pointer
arp oil pan studs
arp main studs
ADD 600
ADD 3325
ADD 250
$6275 for above
Re: 498 ala cart
ok, Ill get you a qoute..for the short block
