[CA] Third Gen Rear Disc Brake Posi rearend
I have an 87 Camaro/Firebird rearend for sale at $350 firm. It is a 9 bolt Aussie rear with 3:27 posi and disc brakes in super condition. The brake calipers are mounted one on the rear of the rotor and the other on the front of the rotor. Comes with brake cables complete. Contact me at 661-943-1739 or email me at paterrachevy@yahoo.com and live in California zip code 93536
Re: Third Gen Rear Disc Brake Posi rearend
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
What's the difference between an "Aussie" and US rear?
The US gear is a gm corporate 10 bolt, the aussie gear is a borg warner built in australia 9 bolt cone style posi
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Interesting. And I'm interested but you're too far away (400 miles) to make a special trip. Is it externally all the same as the US set? How did an Australian built rear get here? Were they used on US 3rd gens? I have to go to Santa Barbara in July so if you still have it then maybe, if it's more or less a direct bolt in.
The 9 bolt was factory equipment on the performance optioned cars
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Do all the disc rear ends have one caliper in front and one behind?
All the early ones yes, the later ones and the 1LEs got the alu pbr rear calipers, they are both trailing, not one trailing one leading.
Typical GM, cheaper to make 1 part and use it on both sides
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
