[KS] interior A/C assembly- complete
Old Aug 10, 2011 | 11:22 PM
  #51
banksGTA's Avatar
Car: 87 GTA
Axle/Gears: 3.42 posi
Re: 91 350 part out, Nitrous, TPI harness, 730 ECM more!
Originally Posted by camarotucker
I can not, however, send me your email and I will send it tomorrow.
rebal_4_ever2003@yahoo.com Thanks
Old Aug 10, 2011 | 11:31 PM
  #52
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
i dont know if its needed for the ls1 swap but are you selling the throttle cable?
Old Aug 11, 2011 | 07:55 PM
  #53
banksGTA's Avatar
Car: 87 GTA
Old Aug 11, 2011 | 08:03 PM
  #54
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Throttle cable got sent with the HSR. I will get on it now banksGTA.
Old Aug 11, 2011 | 08:43 PM
  #55
banksGTA's Avatar
Car: 87 GTA
You take 200$ shipped?
Old Aug 11, 2011 | 08:47 PM
  #56
Car: 91 z28
Transmission: 4L60e
$250?
Old Aug 11, 2011 | 09:44 PM
  #57
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Willing to. Sell the serpentine setup? I need both brackets,tensionern ac delete if you have it and all bolts and braces for the setup. Lmk I know you said you may seperate if you don't sell motor. Thanks
Old Aug 11, 2011 | 09:55 PM
  #58
Car: 91 z28
Transmission: 4L60e
I have all bolts. I have all brackets. I scrapped the tensioner. I left the A/C compressor on for the belt routing. I sold the crank pulley. Smog pump was scrapped.
Old Aug 14, 2011 | 01:08 PM
  #59
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 91 350 part out, CSR starter, TPI harness, 730 ECM more!
Are the heads still good the l98'heads that were on your engine?
Old Aug 14, 2011 | 08:21 PM
  #60
iceman383ja's Avatar
Car: 91 Z28, 2014 ZL1
Engine: 383, LSA
Transmission: WC T-5, T6060
Axle/Gears: 3.73 in both
Will you sell the rocker arms? if so, how much?
Old Aug 14, 2011 | 08:39 PM
  #61
IROCZ1989's Avatar
Car: 1989 IrocZ
can you give me shipping to 02790? thanks
Old Aug 15, 2011 | 07:12 PM
  #62
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I am interested in the harness and the ecu. Can you separate the Moates chip adapter with AUJP memcal?
Old Aug 19, 2011 | 11:31 PM
  #63
Car: 91 z28
Transmission: 4L60e
ttt
Old Aug 20, 2011 | 10:00 AM
  #64
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Interested in the oil pan, how big is it? Do you have the part number for it? Any dings or dents? I need one for a 1 pc rms small block into an 88 Camaro. Thanks
Old Aug 22, 2011 | 09:01 AM
  #65
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
was wondering if u have the ESC if so how much shipped to 18428?
Old Aug 23, 2011 | 01:30 PM
  #66
67hotrod's Avatar
Car: Camaro
Engine: 6.0L LQ4
Transmission: 4l80E
Axle/Gears: 12bolt 3:42
tpi harness speed density $130 shipped
Ecu 730 with burnable chip and Moates chip adapter with AUJP memcal $150 shipped
I am interested in this^^^
Old Sep 18, 2011 | 06:53 PM
  #67
Car: 91 z28
Transmission: 4L60e
Items added, make offer must go
Old Sep 19, 2011 | 12:53 AM
  #68
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
how much without the ecu
Old Sep 19, 2011 | 12:45 PM
  #69
Car: 91 z28
Transmission: 4L60e
PM sent
Old Sep 25, 2011 | 07:35 PM
  #70
Car: 91 z28
Transmission: 4L60e
Re: 91 350 part out, CSR starter, TPI harness, 730 ECM, Memcal, more!
bump
Old Sep 25, 2011 | 11:22 PM
  #71
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
pm about heads and block
Old Sep 27, 2011 | 01:35 AM
  #72
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
I didn't look through all the posts, but private msg me about the starter. I'm building a 12.0:1+ compression, my stock starter might do it, but not likely, 10.75 or 11:1 is usually the limits for "stock"
Old Sep 27, 2011 | 03:59 PM
  #73
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
if I read all of the posts correctly, the 730 ECM is still available?
I would be interested in the ECM and Memcal if they are available.
Could you shoot me some info, and pricing to: vrodpete@msn.com?
Thanks,
PK
Old Sep 28, 2011 | 08:53 PM
  #74
Car: 91 z28
Transmission: 4L60e
PMs replied
Old Sep 29, 2011 | 06:22 PM
  #75
Re: 91 350 part out, TPI SD harness, heads, block, more
I appreciate the "Priavate message" I receibeved, its clearly not there. I didn't buy your parts, because your far away, I boughta whole new motor & its build to handlge 800+ hp, rather than spending gas money to drive 700 miles there, and 700 back. So, clearly now, hope you sold the rest of your s h i t
Old Sep 29, 2011 | 06:32 PM
  #76
Car: 91 z28
Transmission: 4L60e
No I dont have a site with the car on it. It is not really presentable. It is a work in progress, LS1 right now, then I want to clean the engine bay up and freshen up the interior before I take pictures of it. Cant wait to see the progress on your engine, sounds like it will be fast. I will check on this pan tomorrow, its hot (110) and the heat pushed me out of the garage and into the house.
Quote:
Originally Posted by cronsformula350
Nice, I'm glad you sold it, I have to use my current one anyway, I am also low on funds, but now have to build a forged motor. Do you have a site with more info on your car? I always like seeing others car guys work and what not, Keith.
HSR only? No throttle body?
well what would be ok?
$650 shipped HSR and BBK throttle body
No offense, but I just spent $500 on the strongest GM block, forged rods, bearings, flexplate, solid roller lifters, and some serious other stuff to buy later, but I paid $$500, I'm getting my crank for $400 and $100 for the sfi 19.1 damper, so 500 to finish the bottom end! Thats less for a lot more, I have that intake, but maybe sell it to someone else that wants to spend that much. The economy is ****ed up now, and a lot of guys are selling a lot of **** at a loss, because they need the money. I need money, but I'm building a 800hp bottom end, 1000 on spray lol, lightweight, HIGH compression. 10.96:1 with my current heads. So try to find someone willing to pay that much, I mean I know I spent $680 on mine, but had extra parts
sold
Old Sep 29, 2011 | 06:44 PM
  #77
Car: 91 z28
Transmission: 4L60e
I replied to all Private Messages, and to many of yours. My apologizes for missing your question here on the thread, as soon as you asked about the starter I recived a payment for it and a note that came with the payment stated that it was need for a high compression build. I never put it together that it was two diffrent people inquiring about it. Glad to hear that you are closing in on finishing your build and look forward to seeing some pictures posted of it here on the boards.
Old Oct 18, 2011 | 09:21 PM
  #78
Car: 91 z28
Transmission: 4L60e
bump
Old Oct 19, 2011 | 11:24 AM
  #79
Still need an oil pan and a new water pump lol, I even bought a good TPI 305 to drive my car for the rest of the year lol, while I build the other one
Old Oct 19, 2011 | 07:33 PM
  #80
theno1prince's Avatar
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
PM sent
Old Oct 22, 2011 | 11:15 PM
  #81
Car: 91 z28
Transmission: 4L60e
heads-assembled sold
Old Jan 14, 2012 | 06:07 PM
  #82
bigjcfiredog's Avatar
Car: 91 RS
Engine: Vortec 350 TBI
Did you ever sell the rest of the serpentine setup? I am interested, all of it. You don't have to ship I can get to Wichita. Thanks, John
Old Jan 15, 2012 | 11:46 PM
  #83
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: 91 350 part out, TPI SD harness, door ding moldings
How much for the door dings molding? What color is the underlaying color of the plastic?
Old Jan 16, 2012 | 07:07 PM
  #84
Car: 91 z28
Transmission: 4L60e
The serpentine was scrapped. Door ding moldings you can have for shipping costs, they are at the shop with the car, I can look tomorrow at what the plastic color is. They are off of my 91 so they are the wider style. If you send me your e-mail address chevy86 I will send you pictures tommorow night.
Old Jan 16, 2012 | 07:47 PM
  #85
Sold!!!!!! Silent_for_life@yahoo.com . I need those moldings. Thanks man. I appreciate it. Chevy86 IROC-Z
Old Jan 16, 2012 | 09:52 PM
  #86
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
pm sent
Old Jan 20, 2012 | 12:33 AM
  #87
Re: interior A/C assembly- complete
camarotucker, they look good (ding moldings)! Find out the shipping costs and Ill paypal you a payment. Im in no rush so if you can send it via USPS, that would be perfect. Thanks camarotucker. PM me your Paypal email account so that I can pay for the shipping.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
