[IN] my 91 LB9 5speed TA got smashed by a tree, now parting out...
Old 08-15-2011, 09:33 PM
  #51
jediknight1912's Avatar
Re: my 91 LB9 5speed TA got smashed by a tree, now parting out...
PM sent
Old 08-16-2011, 11:33 AM
  #52
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
What shape is the harness in?
Old 08-16-2011, 11:50 AM
  #53
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I have 2 complete SD harnesses and ECMs. One has the stock 91 305 auto MEMCAL and the other has a hypertech chip. The one harness I got used and is in good shape, the other harness that was in my car is perfect and is completely labeled. Neither harness has any splices or cuts that I'm aware of. My TA ran perfectly for 40k miles that I owned it so I know the harness is good. The other harness was on a running car as well so I assume it's fine but I never heard the car run.
Old 08-16-2011, 11:53 AM
  #54
Mongoose's Avatar
Car: 90 Formula
Are both for manual cars?
Old 08-16-2011, 12:00 PM
  #55
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Do you have the shift plate? Would it fit an 86 or is it a different style?
Old 08-17-2011, 06:17 AM
  #56
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Both harnesses are for automatic cars, but frankly I don't think there is a difference. The only wiring I do when I swap a car over is for the park/clutch/neutral switch. The 4-wire plug for the auto trans just gets zip tied out of the way and not used. The VSS is the same for either trans, and finally I wire up the back up lights from the stock auto shifter to the switch in the side of the trans. None of this affects the engine harness.
The other SD harness I have was also out of a converted 5spd car and I don't think anything there was changed either but I'll have to check to be sure.
Old 08-17-2011, 06:18 AM
  #57
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
shift plate is not available. the one I have is converted from an auto plate which actually works quite well. search my screen name and see how I did it.
Old 08-17-2011, 11:57 AM
  #58
dabomb6608's Avatar
I dont have one at all even to convert. So your converted one isnt for sale?
Old 08-17-2011, 01:07 PM
  #59
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
no the converted shift plate will be going in my GTA when I do the T56 swap this winter.
Old 08-17-2011, 01:21 PM
  #60
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I am interested in one of the SD harnesses and ECU if you still have one.
Old 08-23-2011, 06:59 PM
  #61
FirebirdDude88's Avatar
Car: 88 Firebird formula clone
Engine: Yeah its in there
Transmission: Thats in there too
Axle/Gears: Yeah there in the back
you wouldnt happen to have the emblem that says "pontiac" that goes on the headlight do you?
Old 08-23-2011, 10:25 PM
  #62
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
91-92 cars don't have that emblem. the headlights are flush with the nose...
Old 08-30-2011, 10:27 PM
  #63
i got a few questions.. did this car have disc brakes? if so, how much for just the brakes, also, how much for just the rear sway bar? and one other thing, how much for all of the impact stripping on both sides of the car?
Old 08-31-2011, 12:00 PM
  #64
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
you've got a PM
Old 09-21-2011, 11:14 AM
  #65
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
bump. still got the car and a decent amount of stuff. let me know what you guys need and make offers! This stuff has to go!
Old 09-21-2011, 11:27 AM
  #66
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Do you have the intake snorkel and all that stuff?
Old 09-21-2011, 05:43 PM
  #67
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I've got the snorkel, air filter can, throttle body bellows. I've even got the stamping that mounts the air filter can. What all do you need?
Old 09-21-2011, 09:21 PM
  #68
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
did this car have working ac? I need good ac components, compressor, condenser, evaporator, dries, lines, pretty much everything if it had working ac.
Old 09-22-2011, 05:39 AM
  #69
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
it DID have all good AC components. I swapped it all into my GTA. On that note however, if you remove the hood you can swap the whole AC setup from one car to another without cracking a line open. My 91 had cold AC (i retrofitted it all to R134) and I took it all out and dropped it into my GTA and instand cold again LOL.
Old 09-22-2011, 09:17 AM
  #70
sum_drummer_16's Avatar
Car: 1983 Z28
Engine: Lt1
Transmission: t5
Axle/Gears: 4th gen limited slip
i would like the chipped computer for the 350 with a harness if you still have it. would you take $200 for both?
Old 09-22-2011, 10:14 AM
  #71
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
how much for the y-pipe? and the demensions please. thanks
Old 09-22-2011, 11:17 AM
  #72
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
The car did not have a 350 it had a 305. I have a hypertech chipped ECM and an ECM with a stock chip(305 automatic), or I can burn a custom chip for it to your liking. I assume you mean $200 plus shipping?
The custom Y pipe for the car has been sold, I do have an original single cat TPI 350 Y pipe if you want that. That is 2.25 inlet and 2.75 outlet
Old 09-22-2011, 09:59 PM
  #73
Car: 1983 Z28
Engine: Lt1
Transmission: t5
sorry about that, i misread the posting
Old 09-27-2011, 10:24 PM
  #74
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I would like to purchase the stock memcal (not the hypertech), if you sell it seperately.
Please shoot me an e-mail, if you could.
vrodpete@msn.com
Many thanks,
PK
Edit: Not sure if the ecm sold, but if not, I am interested in it, as well as the memcal.
Memcal is the primary target, but will take both if it makes things easier.
Old 09-28-2011, 05:45 PM
  #75
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
vrodpete@msn.com
Many thanks,
PK
you've got mail...
Old 09-28-2011, 06:56 PM
  #76
Awesome-X's Avatar
Car: 87 Camaro
I haven't seen anywhere whether you've sold the trans or not but if not how much are you asking for it?
Old 09-28-2011, 07:45 PM
  #77
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
how about the rear diff 3rd member...?? posi, I am hoping. (or locker or however you want to describe it). Should be a 10 bolt, yes?
Old 09-28-2011, 08:21 PM
  #78
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Originally Posted by 1MeanZ
you've got mail...
Replied back to ya asking if you would sell the memcal seperately, and requested pricing either way (ecm w/memcal, or just memcal).
Old 09-29-2011, 05:41 AM
  #79
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
MEMCAL is sold. I still have 2 7730 ECMs.
Trans is sold (i'll update that)
The rear is a 10 bolt with a good posi, 2.73 gears and drum brakes.
Old 09-29-2011, 10:44 PM
  #80
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
I am restoring a yellow 92 GTA and I am looking for the 14 mm bolt and metal clip that holds the alternator wiring. I believe that all 89-92 TPI cars came with these parts. There is no part numbers available for these parts so I am looking for good condition, rust free parts. Below is a picture for the bolt and clip.
I am also looking for 3 throttle body coolant clamps for 1991-92 TPI cars. I have tried buying them new but the 2 part numbers I have are for worm style clamps. I am looking for clamps in good condition that aren't rusty. Here are some pics:
OK got some pix of some stuff.
Front ground effects pieces. They are banged up but fixable. $50ea OBO
I also need 1 charcoal canistor hose holder. The part number is: 10105274 and unfortunately it is discontinued. The holder bolts in just above the passenger side front fender ground effect and guides the hose through the ground effect. This part was on every 1990-92 Firebird's that came with TPI. I think you may have one in the ziploc bag in your picture. I would pay $10 for it plus shipping if its in good shape.
Below is a picture:
Old 09-30-2011, 04:25 PM
  #81
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Andy I've got a lot of bad news for you LOL.
The charcoal canister hose bracket was shipped when I sold the ground effects pieces.
My car had all worm style hose clamps instead of the tower style ones you posted.
I DO have the alternator wiring clamp but it would need media blasted and re-plated, it is not perfect.
Looking at your sig however, I do have some of the items you're looking for. I have a rear passenger side marker. It is not NOS but is in perfect condition. I also have a leather shift ****. It is not NOS but is in very good shape. It may not be exactly what you are looking for but it is very nice and I'd let it go cheap if you're interested.
Old 10-02-2011, 01:45 AM
  #82
Andy 91GTA's Avatar
pm sent
Old 10-02-2011, 09:59 AM
  #83
91RS5speed's Avatar
Car: 91 RS
I am still interested in a sd harness and ecu. Shipping to 30096.
Old 10-07-2011, 04:19 PM
  #84
sac92transam's Avatar
Car: 92 convertible t/a and 68 firedbird
Engine: 305/402
Transmission: 700r4/turbo400
i would like the door panels and hand rest for a good price shipped to 95693?
Old 10-09-2011, 11:57 AM
  #85
Andy 91GTA's Avatar
Check your pm's.
Old 10-10-2011, 06:12 AM
  #86
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Waiting on payment.
Arm rests are sold, getting measurements and quote on shipping the door panels tonight.
Originally Posted by Andy 91GTA
Check your pm's.
gotta unbox and dig out the intake to get the pix you need. working on that too.
Old 10-10-2011, 08:30 PM
  #87
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
shipping to you in CA will be $80 for the huge box. I've had 3 guys interested and you're all from CA and the shipping scares you all away LOL.
Old 10-21-2011, 10:45 PM
  #88
MORREALE5's Avatar
Car: 1987 IROC Z
Engine: L31 VORTEC
hello,do you still have trans?
Old 10-22-2011, 04:22 PM
  #89
Awesome-X's Avatar
Car: 87 Camaro
How much for the AC lines and heater/ac box shipped to 47424? I don't need the blower motor or anything.
Old 10-22-2011, 06:08 PM
  #90
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
I'm looking for a driver's lower door gfx. Was it damaged or have you already sold it. If not, pics, price, and shipping to 78415?
Old 10-23-2011, 11:29 AM
  #91
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
trans is sold
all AC componens have been sold
I do have the gfx but wanted to sell them whole so I'm not sitting on bits and pieces. would you be interested in the whole shot? Everything minus the front and rear bumper covers and front fender ground effects.
Old 10-23-2011, 07:47 PM
  #92
antares57's Avatar
I recently got a base model 1991 Firebird and the only damaged gfx is the driver's lower door section. Appreciate the offer though. If you decide to part with it let me know. I'll keep tabs with this string. Thanks. Does it have Trans Am lettering on it as the pictured passenger side?
Old 10-24-2011, 05:34 AM
  #93
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
yah both door gfx say Trans Am on them....
Old 10-27-2011, 09:58 AM
  #94
Zed28's Avatar
I'm looking for drivers side power mirror. Thanks
Old 10-28-2011, 03:39 PM
  #95
dabomb6608's Avatar
Did the hydraulic line from the slave to the master cylinders sell with the trans?
Old 10-28-2011, 06:01 PM
  #96
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
don't have one that works
it sold with the trans.
Old 10-28-2011, 10:49 PM
  #97
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
Never saw anything posted about selling the headlight motors. Did they sell or do you still have them? If so, how much shipped to 42303? Thanks!
Old 10-28-2011, 11:25 PM
  #98
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Also do u still have the gauge cluster? Is it a 140 speedo?
Old 10-29-2011, 09:00 AM
  #99
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
keeping them as cores to rebuild in case my GTAs motors go bad
Still have the cluster but it's the 120mph version.
Old 10-29-2011, 09:26 AM
  #100
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Quick Reply: [IN] my 91 LB9 5speed TA got smashed by a tree, now parting out...
