[IN] (sold) built 10 bolt disc rear
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
Have a 12 bolt in my Z-28 and no longer need this. It has an auburn pro posi, richmond 3.73 gears, moser 28 spline axles, main caps are studded, ta performance aluminum cover, and the axle tubes are fully welded. Should easily handle 400 whp with an automatic. It has about 8,000 miles on it and there is zero gear whine. just add calipers, mounting brackets are there. Asking $500 and pickup only. If the distance is reasonable I'll deliver if u wanna pay for the fuel.
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: built 10 bolt disc rear
What calipers were on this originally? PBR 1LE? Where in Indiana are you located?
Very interested in this.
Car: 1989 Iroc
Engine: 383 TPI
Axle/Gears: Auburn Pro-Posi, 3:73's
I am also interested if Carlos 773 doesn't take it. It is exactly the set up I've been looking for.
Go ahead UDE. Just a bit too far of a drive to be worth it (8 hours) for it. If it was closer I would skip a day of work for it.
GLWS
GLWS
Car: 91 Z-28
Engine: 420 sbc
I dont have any messages. Carlos773, are u talkin round trip of 8 hours? I can make it to Chicago from my house in 3.
Car: 86 firebird
Engine: 385 dart pro 1 heads 13 to 1
Transmission: th350 4800 stall
Axle/Gears: 33 spline nine inch
if you want to part it out im interested in the axle shafts and cover
hectre13
Dec 11, 2023 08:14 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
