357 L98 Short Block
Subscribe
Sep 2, 2011 | 03:30 PM
5,500 miles
Complete Rotating assembly
2 bolt main 350 +.040 Hypereutectic H618P .125 Dome plama moly rings gap matched -150g float Rods, drilled end for oil to wrist pin
casting imperfections have been corrected internally & externally
Bi metal rod, main & cam bearings
ZZ4 Steel Crank 14088532 fully Balanced Assembly, with print out, roller pilot
sealed power roller lifters with retainers & spider
Billet CC 306 race core .510 .540 matching springs
H.V. oil pump with stock spring CrMo Oil shaft Steel retainer
brass freeze plugs
F body oil pan
threaded front oil galley plugs
edelbrock double roller timing set, aluminum timing cover
with my combo this engine produced 450+
this this engine ran outstanding 100% when pulled
I can sweeten the deal with other parts I have
if you want a excellent 350 base!!! it's going to be tough to beat
Reply 0
Sep 3, 2011 | 07:27 PM
Re: 357 L98 Short Block
Reply 0
Sep 3, 2011 | 07:28 PM
Reply 0
Sep 12, 2011 | 08:51 PM
Is this the motor with the spun bearing ?
Reply 0
Sep 12, 2011 | 09:02 PM
Eightyninef hold on I'm dying here 100% perfect block
but wait I know where you can get pitted detonated heads from
ohh yes you have a set....
Reply 0
Sep 12, 2011 | 09:07 PM
Dude,
I heard you spin the bearing at E-town, why would you try to sell the motor here ???
And you cut a perfect light too. Shame your motor let loose.
Reply 0
Sep 12, 2011 | 09:14 PM
lol I know for a fact it's perfect and pulled 113 in the 1/4 from 2nd gear @ 2K
have the time slip VSS died and few other car probs
PS never went to E town you jersey TRASH
now show a nice close up of your POS factory Heads that were not surfaced for $700.00 trying to rip people off and detonated
Reply 0
Sep 12, 2011 | 09:35 PM
Nice gravel driveway next to your motor. Did you kick up any dirt and debris while the motor was exposed ?
guess it doesn't matter with the spun bearing.......... The scrap yard will give you $20.
Reply 0
Sep 12, 2011 | 09:42 PM
Quote: Nice gravel driveway next to your motor. Did you kick up any dirt and debris while the motor was exposed ?
look you STUPID jersey retard!!!!!!! my motor is 100% perfect
and 1000% better then anything you will ever have!!!!!
your heads you are selling it's your pic you are posting
they have pit MARKS around the chambers what does that tell you
you are trying to scam someone!!!!!!
Reply 0
Sep 12, 2011 | 10:12 PM
Reply 0
Mar 8, 2012 | 08:36 PM
Still available... again guaranteed in perfect running order.. if you have a HSR or similar
With good heads.. this short block is perfect for you 64 cc' s will give you 11:1
Could have sold it 8 times now I'm honest about a TPI setup on this combo is a terrible plan
Reply 0
Apr 29, 2012 | 08:03 PM
No one has plans to drop there factory motor???
You cannot build this combo with my block prep & mods + machining
This shortblock. just needs heads. And a good intake
Reply 0
Apr 29, 2012 | 09:01 PM
I'd buy it if you were a little closer. Sounds like a good shortblock.
Reply 0
May 6, 2012 | 08:11 PM
SOLD
Reply 0
Subscribe
