[WA] Holley Stealth Ram and Commander 950 PRO ECU/wiring
Old Sep 27, 2011 | 02:21 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Holley Commander 950 PRO ECU Installed into modded thirdgen ECU housing.
Wiring harness for TPI car
I ran a WB02 so you'll need to run one, or buy a 3 wire heated o2 sensor and connector to solder into the harness.
Map Sensor
Distributor - Small Cap EFI OEM
IAT Sensor
GM Small Cap Dizzy Adapter Harness
Software
Serial Cable
$450
Stealthram Intake w/ Fuel Rails w/ Adjustable regulator.
Plenum has fittings on the back for PCV/Interior Vacuum/Regulator/Booster. Also the upper rad hose, water neck, adapter for sensors in the intake and ARP stainless intake bolts.
No Throttle Body/Injectors
Powder coated red base.
Sanded down cast plenum, polished and painted ribs.
Fits old or new style GM SBC Gen 1 Heads.
Uses -6AN fittings. I'll also throw in the Fuel Lines and fittings to make it fit your standard TPI fuel lines on a Camaro for $50 (Well over $100 to buy and make.)
Retails over $600
$350 or $400 w/ fuel lines/adapter fittings
Attached Thumbnails Holley Stealth Ram and Commander 950 PRO ECU/wiring-commander-stealthram.jpg
Old Sep 30, 2011 | 04:54 PM
Jake88maro's Avatar
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
Re: Holley Stealth Ram and Commander 950 PRO ECU/wiring
how much shipped to 44721.
Old Sep 30, 2011 | 05:25 PM
For the intake setup or the ECU setup?
Intake setup will be about $30 priority shipped with insurance.
ECU/wiring/dist will be about $25.
Old Sep 30, 2011 | 05:34 PM
Jake88maro's Avatar
would you just sell the intake and fuel rails also adapters to stock tpi lines?? if so how much?
Old Sep 30, 2011 | 06:00 PM
$435 (calculated the shipping to 44721):
Intake Base
Plenum
Fuel Rails
T-Stat 180
Water Neck
Upper Rad Hose
Braided -6AN Fuel Lines
Adapter fittings for the TPI fuel lines that come up infront of the master cylinder.
Old Oct 1, 2011 | 01:27 PM
minijensen's Avatar
Want a title? Post!
Car: 1991 camaro
Engine: 305 v8
Axle/Gears: 3:08
do you still have it?
Old Oct 3, 2011 | 05:21 PM
~SOLD~
Old Oct 8, 2011 | 10:34 AM
IrocEspo28's Avatar
Car: 1988 Camaro
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 373
Is everything gone? Looking for the ecm and harness?
Old Oct 30, 2016 | 07:52 PM
one sick gta's Avatar
Car: 1987 GTA
Engine: 383
Transmission: Tremec 3550
Axle/Gears: 373
hey i think i have your old stealth ram set up. i bought it off a guy from marrietta ga. just looking at the pictures its identical to the point
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Royal_Z
Sep 30, 2015 08:45 PM
mfp189
Sep 27, 2015 09:25 AM
