[IL] Edl 130gph Fuel pump, 3" AL Driveshaft, Cam + Rockers, Stewart Waterpump
Old Nov 28, 2011 | 07:22 PM
slim64's Avatar
Car: 64 Impala, 86 Z28 Camaro, 00 C5 FRC
Parts for sale, will no longer be needing this stuff so its got to go.
Driveshaft: Spun aluminum 3" driveshaft, th350 to 9" length. Spicer 1350 yoke and joint, rear ujoint needs to be replaced. $200
Fuel pump: Edelbrock #1711 130gph mechanical fuel pump, great shape, used for 3 seasons. Unit has a clockable base to help with clearance issues. includes lightweight pushrod for cast cam. $50 (will include AN fittings at buyer request)
Cam: Variation on the Comp 305H hyd flat tappet cam, little more duration with a 4/7 swap grind. 537int .535ex with a 1.5rocker. 253 duration
$65 Cam made 498HP 496TQ on 93 octane with a mild sbc build.
Video of car to hear cam
http://www.youtube.com/watch?v=ddc8F-G5DH0
Rockers: Crane silver 1.5 roller rockers 7/16th stud. used for two seasons. $100
stewart stage 2 mech water pump. New never used, meant for serpentine belt setup. $100
Prefer local pick-up for everything but shipping can be arranged.
Prices are negotiable...lets get this stuff gone!
Email me for quickest response.
THANKS!!
all stuff located in Lansing IL 60438
Old Nov 28, 2011 | 07:33 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Q-850 Hooker Longtubes and other goodies FS
that driveshaft will also work for a 700R4 transmission as its from a long tailshaft th350 and out of my car from years ago....
Old Nov 28, 2011 | 07:43 PM
slim64's Avatar
Yes it was. Thanks for the additional info.
Old Nov 28, 2011 | 07:51 PM
slim64's Avatar
Old Nov 28, 2011 | 10:51 PM
WilliamSilver's Avatar
Re: Q-850 Hooker Longtubes cam fuel pump and other goodies FS
Rockers self aligning?
Old Nov 28, 2011 | 11:27 PM
slim64's Avatar
Heads had guide plates, so im guessing no. Ill get the part # tomorrow and post it here.
Old Nov 29, 2011 | 03:57 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Any pics of headers & exhaust? Thx.
Old Nov 29, 2011 | 05:14 PM
slim64's Avatar
Shot of the yoke on the driveshaft
Another of the back of the water pump, this is a reverse rotation and needs to be used with a factory serp belt setup.
Kinda hard to see, but the clearance was actually really good due to the oval pipe and thin muffler.
Old Nov 29, 2011 | 06:41 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
The mufflers look like they'll be too low for my car though (lowered 2"). Would you consider selling just the headers? How low do they hang? Thx.
Old Nov 29, 2011 | 07:18 PM
slim64's Avatar
Headers hang lower than the exhaust/mufflers.
At this point id like to keep the headers/exhaust together since they were built as a set. If buyers come up for each i will separate.
Old Nov 29, 2011 | 07:30 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
K, guessing neither will work for me then. Setup sounds awesome though, GLWS!
Old Nov 29, 2011 | 08:03 PM
88gunmetalgta's Avatar
Would your exhaust setup work with a 700R4/stock K-member? Or could it or the K-member be modified to make it work? I guess a pic would be worth 1000 words here lol. I'd like to see some installed pics.
Old Nov 30, 2011 | 10:11 AM
slim64's Avatar
Re: Q-850 Hooker 2210, TCI, Al Driveshaft, Other performance parts.
I dont have a pic with the stuff installed, but 700R4 and a th350 are the same size so clearance wont be a problem in terms of the trans pan/crossmember. The Spohn trans member is much larger than the factory one.
I have a stock K-member on the car and no issues with the headers.
Old Nov 30, 2011 | 10:16 AM
slim64's Avatar
Old Nov 30, 2011 | 11:01 AM
Well I'm very interested. Post up some pics showing the routing and current condition.
Old Nov 30, 2011 | 11:22 AM
slim64's Avatar
Old Nov 30, 2011 | 11:54 AM
Can you get a shot of what the headers look like now? You said the previous pic was when you first got them.
Old Nov 30, 2011 | 11:55 AM
slim64's Avatar
They are still bolted to the motor, once i get them pulled off ill get pics for you.
Old Dec 3, 2011 | 10:21 AM
slim64's Avatar
Old Dec 6, 2011 | 11:58 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
what size primarys?
Old Dec 7, 2011 | 12:04 AM
slim64's Avatar
Originally Posted by daturbosix
what size primarys?
1 3/4" and a 3" collector
Old Dec 7, 2011 | 12:21 AM
Did you get my last PM?
Old Dec 7, 2011 | 12:25 AM
slim64's Avatar
Dont think so?
Old Dec 7, 2011 | 12:30 AM
Dont think so?
Pm'd again.
Old Dec 7, 2011 | 12:36 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
so slimmy... PM what you want for just the headers.
Old Dec 10, 2011 | 03:15 PM
Cody Ashby's Avatar
Car: 1991 Firebird Formula
Engine: 6.0 LQ4
Transmission: TKO600
if he wants just headers ill take the rest of the exhaust. PM me if you are willing to do that. Thanks alot
Old Dec 10, 2011 | 03:41 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Rockers work with an lt1?
Old Dec 10, 2011 | 05:07 PM
slim64's Avatar
Honestly dont know, only issue i could see would be clearance with the centerbolts for the valve covers. I had them on a set of dart iron eagles.
Old Dec 12, 2011 | 12:33 PM
slim64's Avatar
Payment for Q-850 carb received.
Headers/Exhaust sold.
Old Dec 16, 2011 | 10:22 AM
slim64's Avatar
Original post updated.
Lets make some deals!
Old Dec 16, 2011 | 03:20 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
looking for a back up drive line.
is it in good shape dings dents? (yes i see it needs a U joint)in your post
has for the tube..Good shape?
My set up was to use any Factry GM 3rd gen drive line.
I have in My car a 700R4 to a currie 9". Factry parts drop right in. would this Be the same set up?
you can PM me
Old Dec 16, 2011 | 03:29 PM
slim64's Avatar
you can PM me
Both Steve and i have Moser 9" rear axles, the length should be the same for you, so there wont be any length issues.
The tube has some minor scratches, but no dents or dings.
Old Dec 16, 2011 | 03:59 PM
Re: Edl 130gph Fuel pump, aluminum Driveshaft, Tq Converter, Rockers
can you take a look at the rear u joint. and give me the size specs
U joint across Size
U joint Cap Size
see if its a bolt in for me /or close
Jeff
Old Dec 16, 2011 | 04:09 PM
slim64's Avatar
U joint across Size
U joint Cap Size
Jeff
Its a 1350
Depends on your yoke on the rear axle. Since the joint on the driveshaft is bad you can just get a universal to fit whatever yoke you have on the rear axle.
Old Dec 16, 2011 | 04:18 PM
i ask. has i wanted to know if the size was the same has mine.
1350 is all aftermarket size stuff. and can be 2 or 3 diff sizes
this is what i have seen. .
back to the bolt/drop in parts. ill go out and get a look at what i have now.
i do know mine is Billet and had the Daytona pinon support housing stuff sweet looking
red anodized stuff
Jeff
Old Dec 16, 2011 | 05:04 PM
slim64's Avatar
red anodized stuff
Jeff
Sorry but that is not true. 1350 is only one size.
http://www.dennysdriveshaft.com/freq...questions.html
They do make conversion u-joints for the most common sizes.
Old Dec 16, 2011 | 08:40 PM
xpndbl3's Avatar
Car: 1984 Z28
there is only one 1350 size
there is a 1310, 1330?, and a 1410 in all different sizes though.
Only one industry standard 1350 size for both caps and spacing on the driveshaft. ANY 1350 yoke will fit it made by moser, strange, spicer, etc etc
Old Dec 16, 2011 | 09:41 PM
Aren't those numbers just spicer u-joint part numbers??
You should be able to cross reference them to any given manufacturer. Of course if you need to adapt it, you'll end up with an oddball number.
Edit: xpndbl3 was right, 1310 and 1330 are available in two cap sizes, there's only one 1350.
Old Dec 17, 2011 | 02:41 AM
maby its the 1410 i was thinking of not sure. forgive me.
i remember the 1350 was aftermarket for cars.
it's been years. from the time i played with the parts. just starting over.
cars been sitting for the last 9 years.
have to get My info out. on what parts i had installed.
forgot to ask..Who made the drive line?
Old Dec 17, 2011 | 03:41 PM
slim64's Avatar
I dont know the company that made the driveshaft. perhaps steve does.
Old Dec 19, 2011 | 01:33 AM
xpndbl3's Avatar
Car: 1984 Z28
I "believe" it was suburban driveline, it's "thee" shop in the chicago area for driveshafts. There's another one of these driveshafts in a buddies camaro with a D2R procharger on it making 22 pounds of boost in a footbrake car.
Old Dec 22, 2011 | 07:58 AM
  #42
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
pm'd
Old Dec 22, 2011 | 02:07 PM
  #43
slim64's Avatar
Pm's returned.
Old Dec 28, 2011 | 07:02 PM
  #44
slim64's Avatar
Updated list and bump.
Old Feb 9, 2012 | 05:23 PM
  #45
slim64's Avatar
Re: Edl 130gph Fuel pump, 3" AL Driveshaft, Cam + Rockers, Stewart Waterpump
Bumpski for the new year.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
92camaroJoe
Aug 13, 2015 06:07 AM
