[CA] Forged Gen1 rotating assy. (pics)
Old Dec 15, 2011 | 09:30 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
4340 forged crank
3.48 stroke
2 pc rms
Manley 6" Sportmaster rods with floating pins
ARP capscrews
Good to 550hp
Manley Platinum series flat tops .040
420g forged
piston PN 48204
60 (sixty!) miles on everything, only. Paid over 1800 for all this
balanced by The Balance Shop in Reseda, Ca
$850+ship.
Crank had some light shmutz probably from initial run in. Had it polished by same place once it was apart. Can alllllmost see some faint lines cant feel them. Run it as is.
also have a custom comp billet solid roller cam 60 miles on it cherry
paid 600 sell 300 firm
280/286
250/254
110 lsa
with 1.6 670/660 gross lift before lash. 1.5 easy to do the math
Sounds nasty will still pull 10 in vac at 1000. Good driving manners despite its sound.
Old Mar 3, 2012 | 02:47 PM
The_rabbit1's Avatar
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
Re: Forged Gen1 rotating assy. (pics)
is this still for sale? very interested, for a 383 setup yes?
Old Mar 3, 2012 | 04:59 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
4340 forged crank
3.48 stroke
2 pc rms
Not unless it's a .60 over 400 in which case you'll need special main bearings.
Old Mar 3, 2012 | 10:28 PM
Car: '87 Iroc
I R confused, the pistons say .040 over.. I was asking do these go in a 350 or a 400.
Old Mar 4, 2012 | 08:18 AM
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
He was replying to your post about wanting a 383..., 3.48 crank is for a 350,making this a long rodded 350 (its close to my setup but I'm. 30 over)..... 383 has a crank size of 3.75
Old Apr 24, 2012 | 11:30 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Sometime guys think a 350+30 over=383, but it's not
however 350 bored .030 over = 355
now a 350 sbc with a 400 crank = 383
ect ect.....
Last edited by 85gulstrandTA; Apr 26, 2012 at 09:16 PM. Reason: fixed 350 sbc with a 400 crank = 383
Old Apr 25, 2012 | 03:24 AM
Twin_Turbo's Avatar
400 with 350 crank will give you a 377 screamer
nonetheless, really nice rotating assy so free bump
Old Apr 25, 2012 | 05:46 PM
Car: '87 Iroc
however 350 bored .060 over = 360
now a 350 sbc with a 400 crank with .030 overbore = 383
now a 350 sbc with a 400 crank with .060 overbore = 388
ect ect.....
fixed
Old Apr 26, 2012 | 09:12 PM
fixed
Thanks, I messed that up...glad you knew what I meant.
400 crank in 350 block ect, ect
Run out of coffee and brain farted.
There is a member C409 looking for a solid roller cam, that started a new post.
Old Jul 11, 2012 | 09:53 PM
Axle/Gears: 4.11
Thanks TT, assembly is sold. Someone got a smokin deal at $800
gta892000
Aug 11, 2019 11:16 AM
87v6Bird
Jul 1, 2018 04:12 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
camarohelp
Sep 22, 2015 03:19 PM
