[Sold] Comp Cams OE Roller Camshaft, Xtreme Energy
Old Jan 21, 2012 | 10:02 PM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Hello All,
I have for sale a Comp Cams XR258HR-12 camshaft. This cam is nearly identical in pattern to the GM Performance ZZ4 camshaft, but will fit within the maximum lift limit of factory heads and springs. I just got through pulling the camshaft out of my totaled Formula. It has 15k miles on it, and was installed with new GM Performance lifters and timing chain set. Oil was changed religiously every 3000 miles with Valvoline VR1 (with Zinc additive to reduce friction). The cam is in perfect condition, no nicks, scratches, pitting, or nastyness anywhere.
Here's the specs:
Duration at .050": 206/212
Lift (w/ 1.5:1 rockers): .480"/.487"
Lobe Separation: 112 degrees
http://www.compcams.com/Company/CC/c...?csid=185&sb=2
(this is exactly the same cam as above, but it was ground with a 112 degree lobe separation angle, and is marked as such on the end of the camshaft)
This is an EXCELLENT cam for a performance 305, which is what I had it installed in. Holds good idle vacuum, but has a slight lope at idle. I pulled a best of 31 mpg with this camshaft in my 305 backed by a T56 and 3.27:1 gears. The Powerband in a 350 is listed as 1000-5000, but it pulled hard to over 6000 rpm in my 305. This is also a great choice for a car with unmodified factory heads (or Vortech heads), as it comes in right at the .48" maximum lift of factory heads without valve guide and spring work.
I'd like $125 + shipping for it. This cam sells new for $300 from Summit Racing. First come, first serve. If you're building a hot little street 305, or looking for a nice cam to run with factory L98 or Vortech heads, you won't find a better cam.
-cal30sniper
Old Jan 22, 2012 | 06:04 PM
Engine: L98/454/M20
Re: Comp Cams OE Roller Camshaft, Xtreme Energy
Sale Pending.
Old Feb 12, 2012 | 02:22 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Im not good with cams,is it a roller cam or no?
Old Feb 12, 2012 | 07:26 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Hydraulic roller
Old Feb 12, 2012 | 08:31 AM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
Lifters come with it?
Old Feb 16, 2012 | 03:27 PM
dlw310's Avatar
Want a title? Post!
will you take a hundred shipped? iam in az. contact me at dwcactusaz@q.com thanks.
Old Feb 16, 2012 | 09:15 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Hey I will take it 100 shiped email me and I will send payment soon as I get your ok
Old Feb 16, 2012 | 10:56 PM
Engine: L98/454/M20
There is a sale pending on this. I will let both of you know if it falls through. However, I won't be going down anywhere near $100 shipped. $125 + shipping is a very fair price for this cam considering what they cost new. The Extreme Energy grind is a very modern lobe grind that puts a lot more area under the curve than the older L98 and LT1 cams of similar specs. If no one wants to pay what I'm asking, I'll just keep it and throw it in my L98 some afternoon when I get bored.
-cal30sniper
Old Feb 17, 2012 | 06:01 PM
dlw310's Avatar
Want a title? Post!
lets do this deal. email me with instructions on how to complete this transaction. dave @ dwcactusaz@q.com
Old Feb 17, 2012 | 09:29 PM
Sojer's Avatar
Ok Ill pay what ever do it come with the lifters
Old Feb 27, 2012 | 12:31 PM
Sojer's Avatar
Did it sale I want to mate this with a hsr and 113 heads its like your engine some what lol
Old Feb 28, 2012 | 05:47 PM
Engine: L98/454/M20
I'm waiting to hear back from the guy who said he was going to buy it. If I don't hear by Friday, it'll go to the first person with cash.
Thanks,
-cal30sniper
Old Feb 28, 2012 | 07:51 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Do you have any vid of how it sounded?
Old Feb 29, 2012 | 12:28 AM
Sojer's Avatar
Friday kool I will go with it. I will hold off on the zz4 cam for 165 its new. Can I use new or lightly used retro rollor lifters or do yours come with some
Old Feb 29, 2012 | 07:30 AM
Engine: L98/454/M20
Unfortunately, no I don't. With 1.5:1 rockers, it had a very slight but noticeable rumble at idle. When I switched to 1.6:1 rockers it roughened up the idle a bit more, but it was still smooth enough to hold 17-18" of vacuum at idle. Had just a touch of lope, but not anything lumpy like you hear with the 264 cam on up.
I don't have any retro fit rollers. My block was an OE roller block, so I used LS lifters from GM Performance. I don't know what to tell you about which retrofit rollers to buy, I've never messed with them. This cam will work with them in a pre-86 block though.
-cal30sniper
Old Feb 29, 2012 | 09:47 AM
stealthram92z's Avatar
Car: 92 Z,92 RS,95 SS,00 WS6, 04 XUV
Engine: 383z,350RS, LT1, LS1 ,vortec 4.2
Transmission: 700R4, 700R4,4L60E,4L60E, Auto,
still for sale?
Old Feb 29, 2012 | 12:11 PM
Sojer's Avatar
Ok I will go with some 1.5 picking some up today
Old Mar 2, 2012 | 09:46 AM
Sojer's Avatar
Its Friday droped your money in the bank do u still have it
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
