[NC] Parting out 1988 trans-am GTA
Old 01-22-2012, 06:02 PM
ATOMIC's Avatar
Car: 88 gta (black/black wheels)
Engine: 350tpi
Transmission: 700r
Axle/Gears: 3.27 posi
If you want any parts, please make an offer. With alot of the stuff here, i have no idea where to set the pricing.
88 GTA, 3.27 lsd 9-bolt, WS6 suspension / springs, digital dash.
ws6 suspension package, 4 wheel discs, hollow front sway bar, large rear bar.
black outside, tan cloth ultima interior, steering wheel radio remote.
all prices listed are plus shipping.
rear axle (3.27 posi)complete with brakes-------------$250
front sway bar----------------------------------------$40
rear sway bar-----------------------------------------$35
rolling shell (no engine/trans/harness), clear title-------$500
non-rolling shell--------------------------------------$250
quick ratio steering box--------------------------------$75
L98 cylinder heads---------------------------make an offer
L98 stock cam-------------------------------make an offer
All parts are available EXCEPT:
engine
transmission
ecu
engine harness.
if there are any parts you need from this car ask here, not in a PM.
if there are any pictures you need of parts, ,ask and i will post them up here.
i accept paypal or cash in person.
Old 01-22-2012, 06:09 PM
banksGTA's Avatar
Car: 87 GTA
Axle/Gears: 3.42 posi
Re: Parting out 1988 trans-am GTA
Wondering if the front lower airdam is good and not cracked, also does it have a alum driveshaft? Thanks
Old 01-22-2012, 06:59 PM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
you mean the air dam hooked to the radiator support(not visible)?
i will check tomorrow afternoon.
i think it should have the aluminum d/s, will check on that too.
Old 01-23-2012, 08:12 AM
Yellowzcar's Avatar
Car: 92 Rs
Engine: Ls1
Axle/Gears: 10 bolt 3.73
How much for both front a-arms shipped to 19492?
Old 01-23-2012, 12:23 PM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
how does $25 each sound?
ups shipping calculator says about $40 shipping for the set, but i won't know for sure until they are removed from the car.
so $90 total.
Old 01-23-2012, 12:41 PM
michael110's Avatar
Car: 90 camaro iroc-z
Engine: 5.7 tune port
Transmission: auto (for now)
hey, was wondering if you would sell just the proportioning valve and how much? Shiipping to 37686
Old 01-23-2012, 04:41 PM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
Those seem to usually go for about $35 plus shipping.
I would do that.
Old 01-23-2012, 06:03 PM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
more pics:
keep in mind that it was overcast today, the seats look better in person.
Old 01-23-2012, 06:04 PM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
Old 01-23-2012, 07:49 PM
the gtaman's Avatar
Car: 1989 firebird gta
Engine: sbc 355 hsr 280xfi 58mm tb
Transmission: raptor 700r-4, 2800 stall
how much for ground effects around both doors, and door sills if not cracked shipped to 29153 ?
Old 01-24-2012, 08:26 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'd be interested in a price for the heater control as well as the electric solenoids on the heater box that control the flap doors.
Old 01-25-2012, 07:53 AM
Want a title? Post!
DEADWOOD's Avatar
Car: 1992 GMC
Transmission: 350
If that trunk lock works and you've got a key for it, I'll take it. $10 shipped to 29526?
Old 01-25-2012, 10:53 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
front air dam is not cracked, but still garbage.
aluminum driveshaft, $100 plus shipping.
Old 01-25-2012, 10:58 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
left rocker----------35
right rocker---------35
door sill (pair)-------15
plus shipping, ups ground looks to be around $40
Old 01-25-2012, 11:03 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
i could only find one of those control heads for sale, it was $165.
i would do this one for $100,
flap motors for $15 each,
plus shipping (probably just a flat rate box at $13-15)
Old 01-25-2012, 11:04 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
nope, i don't have a key for the lock. i can re-key it if you want for $20 shipped.
Old 01-25-2012, 11:23 AM
Want a title? Post!
hawk1824's Avatar
Hi,
How much for the gray plastic trim plate that goes around the odometer digital dash? The heater/AC control unit, and the delete place to the left of the rear defroster switch?
Thanks,
Ryan
Old 01-25-2012, 05:49 PM
mstacy1's Avatar
I'm interested in the dual fans if it has them. 77546
Old 01-26-2012, 07:15 AM
Jim85IROC's Avatar
Thanks, but I'll pass. I can usually get entire dashes including the heater controls for that much.
Old 01-26-2012, 11:08 AM
Want a title? Post!
hawk1824's Avatar
Did you get my question? I would also be interested in the heater control motor and flip motors.
Old 01-26-2012, 11:34 AM
dannyvera778's Avatar
Car: 91 camaro
Engine: LS3
how much for the inside door window sweeps?
Old 01-26-2012, 08:49 PM
richfield93's Avatar
Car: many
Engine: mild to wild
Transmission: depends on mood
Axle/Gears: shelf full
does the digital dash work? Miles? How much?
Old 01-26-2012, 11:27 PM
gczj13's Avatar
Car: 84 ta 87 gta 89 ta 89 Camaro 99 z28
how much for the passenger side fender, hood, and the front bumper shipped to 30144?
Old 01-27-2012, 12:59 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
that's why i said, at the top of the page, to MAKE AN OFFER if you want any parts.
Old 01-27-2012, 01:01 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
Originally Posted by hawk1824
Hi,
Thanks,
Ryan
$20 for the trim piece
$15 for the no-subwoofer delete plate
Old 01-27-2012, 01:03 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
are they hooked to the inside door panel? with staples?
or are they clipped on to the door frame?
$15 for the pair if they can be removed without breaking.
Old 01-27-2012, 01:07 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
works fine. all sectors light up, but all are dim.
i don't know how bright it should be though.
170,000 miles.
$100 plus shipping
Old 01-27-2012, 01:13 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
shipping thru UPS ground will be:
$43 for the fender
can't ship the hood, too big
$150 for the front bumper.
as for the parts themselves,
$25 for the fender
$80 for the hood
$70 for the front bumper
Old 01-27-2012, 01:18 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
$100
$130 including shipping
Old 01-27-2012, 06:19 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
got a part number on that quick steering box?
btw is that red thing behind it an omni?
Old 01-27-2012, 06:55 AM
Want a title? Post!
hawk1824's Avatar
Did you sell the heater control unit and flap motors? The gray trim piece have any cracks? Mine does where it bolts the dash top.
Old 01-27-2012, 10:27 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
i can get the number over the weekend.
Eewwwwww, no. It's NOT no omni. It's a rabbit.
Old 01-27-2012, 10:29 AM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
sold nothing so far.
there are not any cracks on the face, i will look closer at the upper screws this weekend.
Old 01-27-2012, 11:12 AM
ownor's Avatar
Engine: LS1 / L03
haha nice, thought the parking/turn signals on the front side gave it away as an omni, but then i'm not exactly sure what these are like on the US rabbits thx on the number
Old 01-27-2012, 11:14 AM
Want a title? Post!
hawk1824's Avatar
Okay, let me know please. I would be interested in anything related to the electronic heating/AC controls as I have some issues with mine not selecting from defrost to heat. I did replace the controller as the cold/hot switch did not work. Also all the hardware holding the trim pieces I could use too as someone put different bolts there.
Old 01-27-2012, 05:00 PM
mstacy1's Avatar
complete dual fan assembly with upper and lower brackets 50.00 + shipping
Old 01-28-2012, 06:43 PM
reaperracer666's Avatar
price on ffenders shipped to 61241
Old 01-28-2012, 07:44 PM
4rcFed's Avatar
Car: 1989 IROC-Z
Axle/Gears: Just About STOCK
I can't recall if ALL '88s had rear disc brakes, but if it does, how much would you want for the rear calipers and mounting brackets (both sides)?
Old 01-28-2012, 11:38 PM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
How is the back aero wing? Is the rubber support along the glass rotten? I think shipping to Canada will be too expensive, but doesn't hurt to ask. Postal code L4Z1N4 Mississauga Ontario.
Old 02-01-2012, 12:21 PM
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
ground effects and door sills sold
Old 02-01-2012, 06:33 PM
bryans88bird's Avatar
Car: 1988 PONTIAC GTA TRANS AM
Engine: 305 TUNED PORT INJECTED
Transmission: T5 BORG WARNER 5 SPEED
Axle/Gears: 3.45 Positrac
How much for digital dash delivered to WA state
Old 02-01-2012, 06:45 PM
  #42
NBrehm's Avatar
Car: 1988 Trans Am GTA
Engine: 6.0 LQ4
Axle/Gears: 3.43
heads aluminum or Iron?
Old 02-01-2012, 07:59 PM
  #43
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
make an offer
  #44
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
IRON.
it's stock
Old 02-01-2012, 11:17 PM
  #45
Call me up I'm very intrested in digital dash 206 612 8510
Old 02-02-2012, 06:42 AM
  #46
Want a title? Post!
hawk1824's Avatar
Hello,
What did you find out on the upper lid on the trim piece?
Old 02-02-2012, 10:56 AM
  #47
michael110's Avatar
hey, did you ever get the valve off?
Old 02-02-2012, 11:31 AM
  #48
ATOMIC's Avatar
Engine: 350tpi
Transmission: 700r
Haven't had a chance to get away from work early enough this week.
Will go on saturday.
Old 02-02-2012, 12:03 PM
  #49
ATOMIC call me up when you get a chance I would like to put somree dewals togeteher thanks Bryan 206 612 8510
Old 02-03-2012, 12:10 AM
  #50
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
If they aren't already sold, I'd be interested in the steering box (if it has no play in it), door lock actuators, upper radiator cover (plastic that goes across the top of the rad/fans) if it has dual fans, door switch (for the inside lights).
Quick Reply: [NC] Parting out 1988 trans-am GTA
