High perf-Complete T5 World Class Setup-Evrything you need!
Old Jan 24, 2012 | 04:06 AM
1RedCamaro's Avatar
Im asking 1000.00 I have invested way over that in this setup. I will ship. Everything is in like new condition as I only put 2000 miles on the setup before the car was hit in the rear.
Heres whats included and what I paid for it
World Class Transmission out of a 1992 GTA 75k with mechanical speedo conversion
I paid 500.00 for the trans alone and still have the ebay receipt
Hurst Shifter 180.00
Bellhousing 100.00
Pedal Assembally 100.00
400 horsepower Centerforce clutch 300.00 (has 2000 miles on it)
300 horsepower Zoom Clutch never installed goes with set. 200.00
Brand new flywheel 130.00
Camaro 5 speed trans(plastic thing that covers the shifter) insert in mint condition 75.00
Mcleods Adjustable Master slave Cylinder 349.00
Two new stock power slave @ 60 each
the stock shifters and master slaves are junk and thats why I upgraded. I had it mounted to a 350 and thats why I had the heavy duty clutch. The 350 was probly only putting out like 300. Everything worked great.
the only other thing you will need is a trans mount, and the backup switch for the 92- i never hooked it up.
ill put a picture tommorow.
Im located in middletown nj
Old Jan 24, 2012 | 05:02 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Re: High perf-Complete T5 World Class Setup-Evrything you need!
Where are you located?
Old Jan 25, 2012 | 02:14 PM
jh_shady01's Avatar
Car: 82 Z28
Engine: Vortec headed 350, lightly worked
Axle/Gears: LS style 7.5, torsen 3.42 disc
Is the new flywheel for a 1 peice rms? X2 on the location!!
Old Jan 26, 2012 | 04:17 PM
boostedv6's Avatar
Are you willing to split this up? I'm interested but only need the following:
Trans
Shifter
Bellhousing
One of the clutches
Old Feb 2, 2012 | 03:58 PM
1RedCamaro's Avatar
the flywheel is for a V8 Camaro. I have no idea what you mean by rms. Its just a stock flywheel that would come on a camaro if you bought it from a factory. Its steel and its pretty light. I looked into an alum one but its only a few pounds lighter.
@boosted- no its not worth it, I wont break it up. Your asking for almost all the parts anyway?
Old Feb 2, 2012 | 06:01 PM
jh_shady01's Avatar
Car: 82 Z28
RMS is rear main seal. 86 and newer are one piece and are externally balanced by the flywheel. 85 and older are a 2 piece style they are internally balanced. I bought another setup anyhow. Good luck with sale.
Old Feb 2, 2012 | 11:13 PM
dirtyracer64's Avatar
Car: 92 Camaro Z28
Engine: 355 HSR ProComp heads
Transmission: 97 Fbody T56 6spd
Axle/Gears: Stock 3.23 10 bolt posi
PM sent
scottmoyer
Sep 7, 2015 07:06 PM
Pino91Formula
Mar 17, 2010 11:34 AM
Willie
Jun 16, 2001 09:53 AM
BLACK Z
May 1, 2001 08:34 PM
BLACK Z
May 1, 2001 06:41 AM
