[FL] Harmonic Balancer & Custom Camshaft. NEW!
Old Feb 5, 2012 | 06:43 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Hey guys, I'm getting my spring cleaning done early this year and I found a few parts that I never used.
First up is a Summit steel harmonic balancer for a Chevy small block, and I'll throw in a new ARP bolt kit for it... $160 shipped.
Harmonic Balancer
ARP Bolt
I also have a custom ground retro-fit hydraulic roller lifter camshaft from Comp Cams that was intended for a 383 build... $250 shipped or best offer. I'll include a cam button.
Intake Duration at .050 inch Lift - 236
Exhaust Duration at .050 inch Lift - 242
Intake Lobe Lift - .3470
Exhaust Lobe Lift - .3600
Lobe Separation - 106
They're all brand new, unused, and still in the original packaging. I'm assuming you all know what they look like, but I could whip up some pictures if you insist. I'll take cash or money orders. And prefer that you contact me via e-mail at SDSanchez88@gmail.com
Thank you, and may the force be with you.
Old Feb 7, 2012 | 06:42 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Re: Harmonic Balancer & Custom Camshaft. NEW!
No reasonable offers will be refused!
Old Feb 21, 2012 | 12:39 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Come on. All you turkeys building engines and no one needs a harmonic balancer?
Old Apr 15, 2012 | 05:22 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I still have both of these wonderful items for sale. Make me an offer!
Old Apr 17, 2012 | 12:33 PM
tpibird305spd's Avatar
Car: firebird
Engine: 355
Transmission: T-5 NWC
Axle/Gears: 4.11
Whats the RPM range for the cam? What lobes did they use.
Old Apr 18, 2012 | 11:28 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Sorry but I'm afraid I don't remember the RPM range. All I have is the info listed above from the build sheet. And it's a retro-fit hydraulic roller lifter cam, if that answers your lobe question.
Old Apr 19, 2012 | 01:33 AM
Car: firebird
Engine: 355
Axle/Gears: 4.11
Could you post a pictuure of the cam card? Cam companies have many more than one type of lobe. Some are lobes designed around class rules for racing, some for street, some for power adders etc. On the cam card ther should be a lobe number for the intake and exhaust lobes. It sounds like one of thier Extreme Energy cams ground on a 106 LSA instead of 110 LSA.
Old Apr 20, 2012 | 07:58 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Here is a scan of the card. If you have trouble reading it just PM me your e-mail and I can send a better copy.
Old Apr 20, 2012 | 11:04 PM
Car: firebird
Engine: 355
Axle/Gears: 4.11
Its basically an XR288HR on a 106 degree LSA instead of a 110 LSA. Just tryin to help you sell it. Dont have any cash at this verry moment but I'll keep this cam in mind. Sounds like a bad @$$ cam for a 383 or 400 build with some good heads.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dusterbd
Sep 29, 2015 08:40 AM
monte87cortez
Sep 26, 2015 08:10 PM
