PRICE DROP Ported S/R Torquer Heads! Part #042670
Car: 88 Iroc-Z
Engine: 388 HSR
Axle/Gears: 9 Bolt 3.70
Selling my used set of World Products S/R Torquer heads. Installed 3/8" screw in rocker studs, bronze valve guides, machined the heads for higher lift cams and pushrod guidplates (which are installed). They have had .040" milled off of them to help increase compression a bit. They were measured at 70cc exactly when milling was done. Intake ports were highly modified and match a 1205 gasket smoothed the bowl, around the guids etc. their is not a spot in the intakes that have not been touched/modified/widened/smoothed out to improve flow. Stainless valves and dual valve springs good till .570" lift are currently installed. Ran them for two years on my carbed 388 in my TA for MAYBE 4-500 miles. The absolute only slight thing wrong with them is one spark plug tip either burned or broke off and put a few very small nicks on the flat spot on the combustion chamber (will not affect anything). Heads are $1040 on summit in bone stock condtion flowing 223 on the intake side and 143 exhaust after all the work on the ports it now flows 262 intake and 182 exhaust flowed at 28" with a 4" bore. Selling to buy AFR's for my new turbo build. Asking $650 for the set. and throwing in howards rev kit to sweeten the deal!!
Car: 88 Iroc-Z
Engine: 388 HSR
Re: Ported S/R Torquer Heads! Part #042670
one more picture!
link to World Products site
http://www.worldcastings.com/product...ron-heads.html
I have invested ALOT of time and money into these heads after they were purchased this is a steal!!
Car: 1990 TA
Engine: 350 in the works
Transmission: th700r
Axle/Gears: 10 bolt Eaton Posi 373
Can you show a pic of the minor damage in combustion chamber ? May be interested...
Car: 88 Iroc-Z
Engine: 388 HSR
The Third picture up top you can see it really good (third cyl. on the right)
Car: 88 Iroc-Z
Engine: 388 HSR
Sorry, no can do Someone else already offered me $750 shipped if I still have them next friday. I would do $650 shipped if you paid right away.
Car: 1990 TA
Let me know what you can do if you still have them 2 weeks from next friday and yes I can pay right away. Good luck, Patrick.
Car: 88 Iroc-Z
Engine: 388 HSR
Now lowering the price down to $650 and throwing in a used Howards Rev Kit in great shape just to sweeten the deal!!!
Car: 1990 TA
Re: PRICE DROP Ported S/R Torquer Heads! Part #042670
Did you sell the heads ? If not, my offer is still there. And free bump.
