KY - TH350 3rd gen swap (trans, shifter, etc.)
SOLD
TH350 trans + parts swap - converted for stock 3rd gen crossmember. $500 obo
I'm in Louisville, KY. Don't want to ship it.
This trans has the aftermarket spacer to push the 3rd gen f-body tail shaft housing back so you can use stock crossmember and torque arm mount. Thats the way my car was set up. I just pulled it out because i'm going with a T56. Has some kind of shift kit and a standard automatic valve body, leave it in drive and let it shift on its own or put it back in one and shift on your own. It runs fine, only problem is a small oil leak on the front. It's been there since I've had it, so 2008. Very minor, doesnt leave a puddle, just residue shows it and pan has red oil on it. I dont know if its the pan or input shaft seal or what. But its not a problem. I've been driving it around since '08. very rarely have to put fluid in it. Its very minor, but its there.
Torque convertor...i dont know anything about it. It was in the car before I got it. But just playing around I can get it to stall up to 3500rpms.
Comes with B&M z-gate shifter and custom center console shift plate. Shift cable. Dipstick and tube. Trans cooler lines. Vacum line. Trans mount. Torque convertor to flexplate bolts. And stock cross member. And the torque arm mount.
(502) 216-5687
dvmeter@gmail.com
(502) 216-5687
dvmeter@gmail.com
Re: KY - TH350 3rd gen swap (trans, shifter, etc.)
I also have flexplates too if you need one, included in price. I have a 153 tooth internal balance. And a 168 tooth external balance.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Wow that's a good deal imo, Mine is set up something like that. That torque converter you have there is an after market for sure. It is maybe 2" smaller in diameter than my 2500 stall that I use with my BB. I sometimes would like (especially on the freeway) would like to have the overdrive which these TH350's don't have.
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
If you decide to sell convertor seperately, let me know.
I'm looking for a T10 drive shaft and trans xmember ... or whole kit ... found most of it ... but these pieces ... I THINK a 350 turbo is the same length ... if you want to part out .. let me know ...
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
Ive got a t5 setup im tryin to trade for a th350 setup.
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
bumb, this is an amazing deal, wish i had the cash for it :/
Transmission: A4
Axle/Gears: 3:23
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
