[NH] AFR-1040
Old Apr 20, 2012 | 07:47 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
AFR-1040
Anyone interested in a set of AFR-1040 heads, 60cc chambers, ordered like that from AFR with #8017 springs. They have about 2 hours of run time. They were built and delivered to me by AFR on 3/2010. Started the motor up and drove it in and out of my garage a few time.
$1200 plus shipping ?
-- Joe
Old Apr 20, 2012 | 07:13 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: AFR-1040
Originally Posted by anesthes
Anyone interested in a set of AFR-1040 heads, 60cc chambers, ordered like that from AFR. They have about 2 hours of run time.
This is a feeler. I'm not 100% set on selling them, but I may very well let them go.
-- Joe
What year were they made and are the the CNC'd set? It seems AFR has been getting better flows every year...
Old Apr 20, 2012 | 09:59 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: AFR-1040
March 2010. They are part # 1040, not the comp ports.
-- Joe
Old Apr 22, 2012 | 11:49 AM
89GTATtop's Avatar
Re: AFR-1040
are these ready to go for an HSR and hyd roller cam? whats the lift?
Old Apr 22, 2012 | 12:29 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: AFR-1040
With the 8017 springs, around .600 lift. At .600 they are like 368lbs open, which is good for hyd roller. Solid roller you would probably want north of 400lbs open.
From what Tony Mamo @ AFR says:
"We set the springs at 1.800
The .600 lift recommendation isn't determined by coilbind figures (some
applications are....some aren't)....in this case we recommend a stouter
spring rate (for .600+ applications). Meaning you could run a .650 lift
cam with our 8017 spring but that much lift is better handled with a
stouter spring (our 8019)."
I'm going with a blower, 99% certain, so I'm going to need 76cc heads so these are for sale immediately after tonight.
Couple people PM'd me. I'll go in order of contact.
-- Joe
Old Apr 22, 2012 | 12:33 PM
89GTATtop's Avatar
Re: AFR-1040
ok well id like them as well... cash in hand. these are not vortec style heads correct?
Old Apr 22, 2012 | 12:37 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: AFR-1040
No 1040 is the traditional SBC pattern.
IrocZ30589 sent me a few PM's on them so I'll give him an opportunity to decide if he wants them or not. I'll report back.
Paypal or cash local pickup. Buyer pays shipping, etc.
-- Joe
Old Apr 23, 2012 | 12:11 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: AFR-1040
Joe, I would be coming up to grab the heads/injectors. I wont be able to make it up until Thursday or Friday, I'll have to recheck my schedual at work. I could send you a deposit if you'd like.
Old Apr 23, 2012 | 12:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: AFR-1040
That sold quick... Very good heads for the money
Old Apr 23, 2012 | 12:32 PM
Car: '89 IROC-Z
Engine: LSx
Re: AFR-1040
Exactly, especially since there already milled which is what I was planning on doing when I finally ordered my set. I wasnt planning on buying motor parts till the body was done but I couldnt pass these up.
Old Apr 23, 2012 | 12:49 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: AFR-1040
No, I don't need a deposit if you are coming up with cash. I'm home after 4:30 PM on week days. I'll put them aside for you.
Thanks!
-- Joe
Old Apr 23, 2012 | 12:51 PM
Car: '89 IROC-Z
Engine: LSx
Re: AFR-1040
Thank you! I'll check my schedual tonight and let you know which day I'll be coming up.
Old Apr 23, 2012 | 04:01 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: AFR-1040
I'm still here, just in case.
Old Apr 24, 2012 | 10:00 PM
Car: '89 IROC-Z
Engine: LSx
Re: AFR-1040
Joe, I will be coming up friday afternoon. I should be making it there right around 4:30. PM me your address when you get a chance.
Old Apr 25, 2012 | 07:14 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: AFR-1040
PM sent! Heads and injectors are on the shelf ready for pickup
-- Joe
Old May 1, 2012 | 08:40 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: AFR-1040
Sold. Thanks!
Bricks34
Feb 11, 2015 12:55 AM
Bricks34
Feb 2, 2015 03:12 PM
gorski123
Aug 30, 2014 08:52 PM
ksith
Aug 8, 2009 12:02 AM
