[MI] C5 Brakes - partial kit SOLD
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Selling my C5 brake set-up because I upgraded to Wilwood. Please note that these calipers need rebuilt, at a minimum, because the dust boots and seals got very hot. They might not be any good at all, I really do not know. A rebuild kit is around $20 ea so it might be worth a shot. Or just plan on throwing the calipers out and buying new. The rest of the components here are in good condition.
^Note on box applies. These Calipers got very hot because of a dragging issue cause by my poor adjustment of the pedal balance bar. These calipers may be junk.
^toasted boots
What is included:
Modified spindles with brackets
Abutment brackets with hardware (pins, boots, bolts, stainless pad sliders)
Calipers that are potentially junk
Goodridge braided lines
What you will still need:
hubs / cut down brake rotors
rotors
calipers or caliper rebuild
pads
It could work out well and you get a cheap kit. Or at the worst you pay the equivalent to retail price for some components and get the spindle modification for free.
Price $250 reduced to $230 SOLD
^toasted boots
What is included:
rotors
pads
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: C5 Brakes - partial kit
What diameter rotor does it use? Do you know what size wheels they inside?
Car: 87 IROC
Engine: 5.3L
This will use the standard C5/C6 12.7" rotor. I think you will need 17" wheels.
Car: 82 camaro z28
Engine: gen 6 454 carburated and cammed
Transmission: ls1 t56 trans
Axle/Gears: currie f9 with 3.70 gears
how much for just the spindles
Car: 87 IROC
Engine: 5.3L
The parts are 45 lbs, and I figure there will be about 5 lbs of packaging so shipping weight is 50 lbs. UPS ground $35. Paypal austingerding at hotmail dot com thanks!
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
How much would shipping be to 90638? (CA)
Car: 87 IROC
Engine: 5.3L
Car: 87 IROC
Engine: 5.3L
Price reduced to $230. I'll also add that I am likely being conservative when I say these calipers might not be any good.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
[NY] Jamex STB SOLD!!
confucius101
Sep 2, 2015 03:34 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
