[IN] Parting 91 ws6 1le firebird
Car: 1989 GTA
Engine: pending install 383 tpi
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
Re: Parting 91 ws6 1le firebird
PM me pics of the rear end bro?
TXs
Dennis
Shipped to Palm Desert 92260?
TXs
Dennis
Car: 1989 GTA
Car: 1989 GTA
Car: 1989 GTA
Car: 1989 GTA
Car: 93 Z28/ 92 Z28 Purple Haze conv
Engine: LT1/305TPI
Transmission: 6 Speed man/ 4 sp auto
Bill here. I am in need of the stock driveshaft safety loop/bar. I need the bar, and mounting hardware. Would you have it? Price shipped to 61080. Il? Thank's, Bill.
Car: 1989 GTA
http://www.umiperformance.com/catalo...3cn0ki2gb6lor5
Engine: LT1/305TPI
Bill here. I'm not looking for an aftermarket setup. All I want is the flat, strap that goes under the front of the driveshaft. I am missing it from my car. It bolts to the brackets on either side of the car, approx. under the front seats. I have an alum. driveshaft. Thank's, Bill.
Car: 1989 GTA
Car: 1989 GTA
Car: 91 Z28
Do you have the factory master cylinder? Don't need prop valve, I have that already, just need MC. Would need it shipped to 35244. Thanks.
Car: 1986 Camaro
Engine: LS6
Transmission: Tick Stage 2 T56
Axle/Gears: Moser 12 Bolt
Still have the weld in subframe connectors? Also, what shape are your shock mounts and spindles in?
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Dibs on black interior pieces pending pix...Do you have the door panels and the plastics that go on them?Thats really what I'm looking for since I have a vert most of the plastics aren't needed..Thank you
Axle/Gears: 3:08
also do you have the relay bracket thats on the drivers firewall by the brake booster and all the relays that go on it...I need the pigtails that go to each relay so I can put the correct relays on my car,someone cut the harness and put some weird relays on it...thanks
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Car: 1989 GTA
Car: 1989 GTA
I do have the door plastics and door panels are custom I can text u pics
Car: 1989 GTA
None of these
Car: 1989 GTA
Car: 1989 GTA
1992 Trans Am
May 10, 2023 07:19 PM
