[IL] LB9 5.0 305 TPI Engine or Part out
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
LB9 5.0 305 TPI Engine or Part out (SOLD)
I am going to buy a 350 short block bored 0.30 over and build a 383 stroker for my '87 IROC... This is the original engine out of a G92 package 1987 manual T-5 IROC-Z.
The good:
Only 82,000 miles on the body and engine. Engine was rebuilt somewhere along the line. Has a mild cam in it. Orange valve covers and rocker arm installation guide I found in the box original owner gave me suggest it was rebuilt.
Alternator only has 500 miles on it (you can tell it looks way newer in the picture).
The Bad:
Making a slight clicking noise from what sounds like the rear of the engine near the bottom. Car idles at very low RPMs and I can't figure out if it's something internal or a sensor problem, but the clicking noise suggests something internal.
Ran great for me for over 3,000 miles since I bought it but rather than rebuild this I am going to go the 383 stroker route. I want more power.
This would be perfect for someone who wants to stay all original and needs a 305 TPI in solid condition.
Whole thing $700 shipped or I'll part it out and we'll discuss price from there for individual parts.
Picture below...
The good:
The Bad:
Picture below...
Car: 1987 IROC Z28
Car: 1987 IROC Z28
Re: LB9 5.0 305 TPI Engine or Part out
^^^^^^^^^^^click the link above and it's the first picture in my album...
Car: 1987 IROC Z28
here is a video of the engine running from a few days ago...
http://www.youtube.com/watch?v=mrC4T...ature=youtu.be
Car: 1987 IROC Z28
BUMP... engine totally fixed... only had a broken valve spring and it's all ready to go and full adjusted... going to swap in the next year or two so keep me in mind if you want a slightly modded 305 tpi with a rebuilt t 5 trans
Car: 1987 IROC Z28
***UPDATE***
Motor will be swapped out in the next year or two depending on my budget and other factors, ect...
LB9 305 TPI with mild cam will come with everything including engine/wiring harness and ECM.
Rebuilt T5 transmission
Both will come as package $1,700 shipped within the continental US. All paperwork provided for the engine work and rebuild of the trans. Message me and I will keep you on a list for when it's time...
Kent
Kent
Car: 1987 Chevrolet IROC-Z Camaro
Engine: LB9 > L98 5.7-liter V-8 TPI
Transmission: MD8 4-Speed Automatic MX0
Axle/Gears: GU5 3.23 G92
Do you have all of the ac compressor brackets? Should be around 7 or 8 pieces ...
Car: 1987 IROC Z28
Car: 1987 IROC Z28
The_Phoenix
Sep 3, 2015 10:56 PM
