Anyone interested in a "parted out" non-world class T5? I'm just throwing it out there in case somebody needs parts (shafts, gears, tail housing). I was going to rebuild it a year ago and cracked the aluminum case-half when trying to press out one of the old bearing cups. After that I kind of lost interest. Otherwise, these parts are getting junked...let me know. Not shipping either...I'm near Baltimore, MD.
Also, I have the poly bushing between tranny and crossmember for sale (no more than 200 miles on it)...$10.
Is it mechanic or electronic speed sensor?
Mechanical
If you want to go to a local UPS store, I'll give you my UPS account #. Just throw it in a box, and they'll do the rest. Doesn't really cost you anything.
midias
close
Any chance it has a 7 tooth blue drive gear I could really use one.
I also need a 21 tooth red but I can actually buy those.
Still have this? I need a shifter assembly.
Still have everything, but i sold the shifter awhile back
midias
close
Quote:
So does it have a blue speedo gear?Originally Posted by dmorse1
Still have everything, but i sold the shifter awhile back Quote:
25 spline teeth inside the purpleish speedo gear...about 6 threads on the OD.Originally Posted by midias
Any chance it has a 7 tooth blue drive gear I could really use one.I also need a 21 tooth red but I can actually buy those.
midias
close
25 spline teeth inside the purpleish speedo gear...about 6 threads on the OD. So the inside gear is purplish and 6ish tooth? How much for it?
Well yeah 6 threads on the outer diameter of the speedo gear. Its free if you pick it up. Or if you pay for shipping i'll send it your way. I'm boxing the rest of it for 'the blur.'
midias
close
Quote:
Did you get my PM I am interested in having it shipped out just give me a quote and a paypal addressOriginally Posted by dmorse1
Well yeah 6 threads on the outer diameter of the speedo gear. Its free if you pick it up. Or if you pay for shipping i'll send it your way. I'm boxing the rest of it for 'the blur.' Sorry for the delay - PM sent
You still have the crossmember and any other sort of mounting? I am making a swap to the T5 and need the mounting for it. Will pay for shipping.
midias
close
I got my gear quickly thank you
Quote:
Only thing I have left is the crossmember and Spohn poly bushing mount (mounts between the tranny and crossmember). I'm selling the bushing for $10...crossmember is free plus the shipping.Originally Posted by conman55
You still have the crossmember and any other sort of mounting? I am making a swap to the T5 and need the mounting for it. Will pay for shipping. Quote:
Great! Shipping $ received.Originally Posted by midias
I got my gear quickly thank you Junior Member
Quote:
I was just wondering if there was anything else attached to it (like a torque arm or something).Originally Posted by dmorse1
Only thing I have left is the crossmember and Spohn poly bushing mount (mounts between the tranny and crossmember). I'm selling the bushing for $10...crossmember is free plus the shipping. The crossmember and bushing mount is all that I would need. If they are in good condition, I would be willing to purchase.
Do you still have any of this left? I need the steel block the shifter goes into, the roll pin, spring, detent ball, plastic bushing and some bolts for the top plate and tail housing.
Sorry, no.
Tags class, gears, nj, plate, shifter, speedometer, support, t5, transmission, transmissions, wc, world
