Non-WC T5 Transmission fluid?
Old Jan 14, 2012 | 12:14 PM
79tagio's Avatar
Car: 1985 Trans Am!
Engine: 355 Chevy Crate Motor
Transmission: Non WC-T5. (gonna blow soon)
Axle/Gears: 3.27s
Hey guys,
I have a question i have a non-WC transmission in my 85 TA and its making some noise i was wondering what fluid should i put in it???? Thanks!
Old Jan 14, 2012 | 12:35 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Non-WC T5 Transmission fluid?
Originally Posted by 79tagio
Hey guys,
Read the T-5 sticky at the top of the page, if you want your noggin to explode. BTW, my 85 Camaro shop manual says ATF.
JamesC
Old Jan 14, 2012 | 02:25 PM
Per James' comment, GM waffled back and forth between ATF and gear lube, with no changes whatsoever to the parts themselves, almost as if from year to year either the warranty dept or the gas mileage dept won control of that spec in a given year.
Other mfrs who used the same transmission with no changes whatsoever to the parts themselves may have spec'ed either of those fluids, or in some cases, motor oil.
Seems like basically any petrochemical you put in there with a viscosity between about 5 and about 90 is probably OK. I wouldn't put in anything thinner than ATF or thicker than 85W-90.
I ran half & half gear lube & ATF alot in my dozens of those. Didn't seem to matter what I put in em though, they all tore up in about as few miles.
Old Jan 14, 2012 | 03:24 PM
79tagio's Avatar
Car: 1985 Trans Am!
Axle/Gears: 3.27s
Yeah i was looking at it and it was just too much info! I was just looking for a easy answer lol thanks i have a built 350 in mine and it sometimes likes to work fine other times itll grind 3rd........ And its not me its the trans itself I think its too much power for it.....
Old Jan 14, 2012 | 03:44 PM
"Power" has nothing whatsoever to do with grinding.
Crashing 3rd and/or 4th is usually a sign that it needs a pilot bearing. Most often it's caused by the clutch gear ("input shaft") being out of line with the mainshaft ("output shaft"). The pilot is what holds the clutch gear in the correct alignment, so when it wears out, it allows the tip of the clutch gear to wobble around, making it impossible for the 3/4 synchro assy, which "bridges the gap" between the 2 shafts so to speak, to work right.
Here's what it looks like and where it is.
A dead one of those will also make it make more noise than it should, and will create the problem where it will have a strange vibe some of the time at engine speed, especially in 4th gear.
Consider changing the clutch out, just because it's probably time anyway, as you replace the pilot.
Old Jan 15, 2012 | 09:43 PM
79tagio's Avatar
Car: 1985 Trans Am!
Axle/Gears: 3.27s
Well its got a fairly new clutch in it now it also makes a loud wining noise in 1st tahnks for the info!
Old Jan 16, 2012 | 11:26 PM
z285.0h.o.'s Avatar
sofakingdom: My engine vibrates when it gets up between2 and 3 grand it does it in or out of gear with the clutch in or out. Do you think that could seriously be where the problem is ?
91Z-TheReaper
Sep 13, 2014 08:02 PM
240zboy
Nov 23, 2011 11:10 AM
Yor
Feb 15, 2010 02:13 PM
maroon88iroc
Sep 20, 2007 02:29 AM
camaro_V6_Tuner
Mar 6, 2004 09:36 PM
