[Sold] Megasquirt 2, Version 3 Engine management and more
Old Mar 19, 2013 | 11:29 PM
MPIpowered4x4's Avatar
For Sale:
Megasquirt 2, version 3,Blue bowling and grippo main board. bought as a preassembled unit. It is currently setup for a sbc 383 multiport EFI,using a TBI/TPI 8 pin ignition module distributor. This can easily be setup to run an LT-1 to get rid of your opti spark.
Comes with serial cable, assembled Relay box ($94 new), ECM, 8 tpi/Lt-1 brand new injector connectors, brand new tpi/tbi igntion coil connectors, coolant temp sensor(new), intake air temp sensor(new). It does have a harness long enough to locate the ecm inside the vehicle. The harness is color coded so you can build the harness easy. I also have a couple of LT-1 TPS sensors that are used so you can plug into a LT-1 TPS sensor. I also have a used lt1 Idle air control valve connector that goes with the deal too. So you can use an LT1 throttle body on your TPI/HSR or whatever.
This ecm can run Low or High impedance injectors, capable of running crank trigger ignition, TPI ignition, Optispark,wasted spark and more. This unit has a built in 2.5 bar MAP sensor
Megasquirt 2, relay box, and all connectors mentioned. $350 plus shipping
Siemans 77lb low impedance injectors used, but flow great. $150 shipped Great E85 injectors!
I can text pics if needed, but I do know the difference in the Megasquirt units and the description is accurate.
Call or text 4055329470
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
evilstuie
Feb 28, 2016 03:33 PM
Thirim
Aug 13, 2015 03:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
