[CO] Pbr e brake cables
Old May 4, 2013 | 05:25 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Pbr e brake cables
here is a picture , the one the outer coating is rubbed through but the cable seems to move.
measure 56 3/4 so I assume they are considered 1434mm
These are for the aluminum pbr 89-92
$30 shipped in the states
Old May 4, 2013 | 09:21 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Pbr e brake cables
was up stranger lol
do these stretch out over time ? i might need these i have too , is there any way too check ? i had the e brake pulled up for couple months so car doesnt roll and it doesnt seem to be grabbing as good as it use too, i have to pull it up to the max lol
bump for great seller
Old May 5, 2013 | 12:08 AM
Engine: Lb9
Transmission: M20
I'm not sure if these stretch much over time, I got the with a set of pbs's I rebuilt and adapters to my 67 camaro. jamesc said there are two different lengths . Im not sure if you car has a equalizer adjustment or not. My wife is making me clean out the garage so a few more parts will be coming lol. I have been stopping bye your ls build. I hope you got your money bock for the exhaust and that all is well man
Old May 5, 2013 | 12:12 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
oh ok i have to check then ...
Thanks again
Old May 5, 2013 | 12:20 AM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/brak...ou-adjust.html
Old May 8, 2013 | 07:34 AM
Engine: Lb9
Transmission: M20
Bump
Old May 8, 2013 | 01:08 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Can u post pics of the ends ??
Your car is equipped with a tunnel mounted adjustable unit .
Old May 8, 2013 | 01:31 PM
Engine: Lb9
Transmission: M20
Old May 8, 2013 | 02:37 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
i thought i seen the adjustment piece awhile back when doing trans swap but never put two and two together i did notice a kink the spring at the end of one and wire is pinch and doesnt more freely maybe road debri caught on to it yesterday
Thanks mybad Tuned Performance for jumping your sale thread thought i might needed it
Pm sent on some other stuff im looking for
Old Jun 6, 2013 | 08:51 PM
Engine: Lb9
Transmission: M20
Bumping
Old Jul 16, 2013 | 03:26 PM
Engine: Lb9
Transmission: M20
Ttt
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
