[OK] parting out
Old Jun 9, 2013 | 09:21 AM
bobalbertyjr's Avatar
Car: 1984 Z-28
Engine: 477 cui Big Block Chevy
Transmission: Powerglide
Axle/Gears: 9" ford with 4.88's turning 14x32's
parting out
MSD Digital 7 plus, part #7520, used but with new wiring pigtails, $300.00
Auto Rod Controls overhead switch panel with underhood remote, used but with new wiring harness, $200.00
Dedenbear BM-1 Delay box used, will take $150.00
Dedenbear TSC-2A used $75.00
Dedenbear spiral cords (4 wire) NEW $35.00 (have two)
RJS window net, 5/10 date NEW, $10.00
Autofab door latches, $75.00
Ed Quay full body width aluminum spoiler, with struts. $250.00 third gen camaro firebird
McAmmis 10 gal fuel cell NEW $125.00
Strange front brake for 82/92 Camaro/Firebird NEW $500.00
Wilwood Residual Valve NEW $10.00 (HAVE TWO)
Four -4 swegeded braided brake lines, with adapters, lock springs and chassis tabs NEW $40.00
Mickey Thompson tubes for big tires, $50.00 apiece or $125.00 for all three
Auto Meter 6013 Replay Race Dash New $1100.00
Afco Schirocco dual pass radiator NEW $200.00
Flex a lite dual fan for above radiator $100.00
Grid tail lights for 82/92 Camaro used $75.00
Monte Carlo LS composite headlights used with mounts $75.00
Shift Noid for forward powerglide, used with spare solenoid $100.00
Summit sealed battery box NEW $50.00
VFN fiberglass dash for fourth gen Camaro/Firebird $150.00
VFN Fiberglass frontend third gen Camaro with 6" cowl hood and Trunk lid $300.00
92 Camaro ground F/X teal $75.00
Five Star molded lexan rear window third gen camaro/firebird $125.00
Lexan side windows third gen camaro/firebird $50.00
NEW Racecraft moly K member, a-arms, caster camber plates, coilover adapters, 200lb springs, lakewood 90/10 struts, moog tie rod, idler, and center link, $1000.00
9" ford housing narrowed, Moser 35 spline axels, four link and panhard bars with rod ends, $500.00
RRR 1.76 glide with brake, deep pan, turbo spline, etc. $1000.00
5500rpm convertor $400.00
470" big block chevy 750-800 horse, fresh from Jim Lewis in vian oklahoma, has not been fired since $2600.00 freshen up. $7000.00
enderlee fuel injection system, Tall big and Ugly 5.562 throttle blades, -1 pump, belt drive poppets pills nozzles, all the stuff is new and ready to install $2200.00
Hooker Super Comp 2.125 primary 4" collector weld up kit with plates for big block chevy $300.00
Nodular center section, 4:86 Pro Gear, 35 spline lightened steel spool, billet pinion support $900.00
All parts local pick up only Tulsa Oklahoma
Contact Bob 918-407-1718 bobalbertyjr@yahoo.com https://www.facebook.com/bobalbertyjr
Old Jun 11, 2013 | 08:14 PM
Car: 1984 Z-28
Re: parting out
updated 6/11/13
Old Jun 12, 2013 | 08:07 AM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
You won't ship any of the smaller items?
Posted from Thirdgen.org App for Android
Old Jun 12, 2013 | 05:46 PM
dennisschreuer's Avatar
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
Re: parting out
Do you have the radiator, fan shroud, rear Lexan window(Thickness?) still in the original boxes?
My son is just outside of Tulsa.
If the stuff is shippable, maybe he can make he hook there and ship it to me.
Originally Posted by bobalbertyjr
MSD Digital 7 plus, part #7520, used but with new wiring pigtails, $350.00
Auto Rod Controls overhead switch panel with underhood remote, used but with new wiring harness, $250.00
Dedenbear BM-1 Delay box used, will take $200.00
Dedenbear TSC-2A used $100.00
McAmmis 10 gal fuel cell NEW $160.00
Strange front brake for 82/92 Camaro/Firebird NEW $550.00
Speedway Motors Stailess overflow catch can NEW $30.00
Auto Meter 6013 Replay Race Dash New $1200.00
Afco Schirocco radiator NEW $200.00
Flex a lite dual fan for above radiator $150.00
Grid tail lights for 82/92 Camaro used $80.00
Monte Carlo LS composite headlights used with mounts $80.00
Summit sealed battery box NEW $55.00
VFN fiberglass dash for fourth gen Camaro/Firebird $200.00
VFN Fiberglass frontend third gen Camaro with 6" cowl hood and Trunk lid $400.00
92 Camaro ground F/X teal $80.00
Five Star molded lexan rear window third gen camaro/firebird $150.00
Lexan side windows third gen camaro/firebird $65.00
NEW Racecraft moly K member, a-arms, caster camber plates, coilover adapters, lakewood 90/10 struts, moog tie rod, idler, and center link, $1200.00
9" ford housing narrowed, Moser 35 spline axels, four link and panhard bars with rod ends, $600.00
Contact Bob Alberty Jr 918-407-1718 bobalbertyjr@yahoo.com
Old Jun 12, 2013 | 07:01 PM
Car: 1984 Z-28
Re: parting out
They are no longer in the boxes, but are brand new. Used to mock up mounts and such, the lexan still has the protective film on it. Your son is more than welcome to come look. I bought brand new parts, as I wanted a nice car when it was done.
I had my car in a chassis shop for 3.5 years, and got jerked around, so finaly I went and got it, the car is cobbled up mess, so I am liquidating all the parts.
And the reason I wont ship, is there are to many whiners. Not pointing fingers, but have had problems with certain members of this very board, and I want to be as honest as I can, with no miss representation, so I would rather deal face to face.
Old Jun 14, 2013 | 11:59 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Re: parting out
Do the ground effects include all pieces? Primarily the front chin piece, if so what condition is it in? I could make the trip from KS if it isn't all torn up.
Old Jun 15, 2013 | 12:27 AM
Car: 1984 Z-28
Re: parting out
All I have is the rocker extensions and the door pieces, the rest of mine were part of the fiberglass front end. If you want, text me your number, and I will send you pictures of them.
Old Jun 15, 2013 | 08:34 AM
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
Re: parting out
How wide is the 9"? I'm in western ok so that's not to long of a drive
Old Jun 15, 2013 | 09:25 AM
Car: 1984 Z-28
Re: parting out
9" ford housing narrowed, Moser 35 spline axels with .625 drive studs, four link, diagonal link, and panhard bars with rod ends go with it, $600.00
37" axel flange to axel flange, the 4 link brackets are on 23.5" centers
will take $500.00 cash
Old Jun 16, 2013 | 07:27 PM
Car: 1984 Z-28
Re: parting out
price reduction 6/16/13
Old Jun 19, 2013 | 07:30 PM
Car: 1984 Z-28
Re: parting out
ttt
Old Jun 23, 2013 | 10:46 AM
Car: 1984 Z-28
update 6/23/13
1. MSD Digital 7 plus, part #7520, used but with new wiring pigtails, $300.00
2.
3. Dedenbear BM-1 Delay box used, will take $150.00
4. Dedenbear TSC-2A used $75.00
5. Dedenbear spiral cords (4 wire) NEW $35.00 (have two)
6. RJS window net, 5/10 date NEW, $10.00
7. Autofab door latches, $75.00
8.
9. McAmmis 10 gal fuel cell NEW $125.00
10. Strange front brake for 82/92 Camaro/Firebird NEW $500.00
11. Wilwood Residual Valve NEW $10.00 (HAVE TWO)
12.
13. Mickey Thompson tubes for big tires, $50.00 apiece or $125.00 for all three
14. Auto Meter 6013 Replay Race Dash New $1100.00
15. Afco Schirocco dual pass radiator NEW $200.00
16. Flex a lite dual fan for above radiator $100.00
17. Grid tail lights for 82/92 Camaro used $75.00
18. Monte Carlo LS composite headlights used with mounts $75.00
19. Shift Noid for forward powerglide, used with spare solenoid $100.00
20. Summit sealed battery box NEW $50.00
21. VFN fiberglass dash for fourth gen Camaro/Firebird $150.00
22.
23. 92 Camaro ground F/X teal $75.00
24.
25.
26. NEW Racecraft moly K member, a-arms, caster camber plates, coilover adapters, 200lb springs, lakewood 90/10 struts, moog tie rod, idler, and center link, $1000.00
27. 9" ford housing narrowed, Moser 35 spline axels, four link and panhard bars with rod ends, 37" flange to flange $500.00
28. RRR 1.76 glide with brake, deep pan, turbo spline, etc. $1000.00
29. 5500rpm convertor $400.00
30. 470" big block chevy 750-800 horse, fresh from Jim Lewis in vian oklahoma, has not been fired since $2600.00 freshen up. $7000.00
31. enderlee fuel injection system, Tall big and Ugly 5.562 throttle blades, -1 pump, belt drive poppets pills nozzles, all the stuff is new and ready to install $2200.00
32. Hooker Super Comp 2.125 primary 4" collector weld up kit with plates for big block chevy $300.00
33. Nodular center section, 4:86 Pro Gear, 35 spline lightened steel spool, billet pinion support $900.00
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
