[Sold] Comp Cams XFI292 $150
Old Aug 15, 2013 | 01:00 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Specs are:
.584/.579 w/1.6 rockers
242/248 @ .050
114 LSA
It is ground on a 1.00" base circle.
Asking $150 shipped in the lower 48.
Old Aug 21, 2013 | 01:57 PM
thewizard's Avatar
Re: Comp Cams XFI292 $150
Still up for grabs.
Old Aug 24, 2013 | 10:35 AM
thewizard's Avatar
ttt
Old Aug 31, 2013 | 02:47 PM
thewizard's Avatar
SERIAL # K 9028-07 SPEC CARD # 12235007 SPEC CARD INQUIRY BY SERIAL #
PART # 07-000-8 CAMSHAFT, LT1 CS LT1 ROLLER
CORE C07-8B CAMSHAFT BLANK, LT1 DUCT SEMI (H.L) Special Grind
GRIND # LT1 3317S /3318S HR114.0
DURATION @ .050 INTAKE 242 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 248 INTAKE 1.50
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3600 EXHAUST 1.50
VALVE LIFT INTAKE .540 LOBE LIFT EXHAUST .3750
VALVE LIFT EXHAUST .562 LOBE SEPARATION 114.0
DURATION .006 INTAKE C/L 114.0
TAPPET LIFT INTAKE 293 CAM ADVANCE 0
TAPPET LIFT EXHAUST 299 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 7 JOURNAL DIAMETER STD 1.868
VALVE OPEN EXHAUST 58 RECOMMEND VALVE SPRINGS
VALVE CLOSED INTAKE 55 DEPARTMENT R
VALVE CLOSED EXHAUST 10 SPC INSTR FOR CUSTOMER
INTAKE LOBE ID 3317S GRIND INSTR FOR CAM SHOP
EXHAUST LOBE ID 3318S
DATE SETUP 05/29/2007
Old Sep 11, 2013 | 12:35 PM
thewizard's Avatar
I also have one of these cams ground on a standard base circle for $200OBO if anyone is interedted in one of those.
Old Sep 12, 2013 | 08:45 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Bump for a good cam at a good price! I have the XFI280 already.
Old Sep 19, 2013 | 12:02 PM
thewizard's Avatar
Thanks for the comment; these XFI cams are great for an off the shelf item.
Old Sep 30, 2013 | 10:52 AM
thewizard's Avatar
ttt
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
punkmaster98
Sep 8, 2015 09:45 PM
Strick1
Sep 4, 2015 07:11 AM
