[CT] 350 SBC & T5
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
350 SBC & T5
Just pulled this combo from my Camaro - I hand built the motor, had it tuned / dynoed, and for the most part - it has sat for the last 5 years. I'm swapping an LSX/T56 combo into the car, so this motor and the tranny need to go. If I were to use the motor I'd re-do all the gaskets except the head gaskets, but it's a great little motor, just needs a bigger cam (I was trying to pass emissions when I built it).
MOTOR $1000
Build Date: 1999
Mileage: 20,000
Compression: Approx 9.5:1
Bottom End:
2 Bolt Block W/ARP Main Studs
1 Piece Rear Main Seal
Cast Crank (Balanced)
Speed Pro Forged Pistons / Moly Rings
GM Powdered Metal Rods W/ARP Rod Bolts
Windage Tray
Top End:
Mild Cam (Made 234 HP @ Wheels In My IROC)
Truck Heads (1.94 / 1.50 Valves) Ported / Polished / Gasket Matched
Induction:
Edelbrock Performer Intake
Edelbrock 600 cfm Carb (Vac. Secondaries / Elec. Choke)
Accel Distributor
14X3" Air Cleaner & Breather Insert
Misc:
Will Include Accessories If Desired
TRANSMISSION $600
Mileage is unknown as it was a swap. I only put ~20,000 miles on it.
1989 Tremec World Class T5
Hurst Short Throw Shifter
Includes Newer Clutch
Includes Matching Flywheel
PM with questions or for my phone number so we can chat. Pickup only.
MOTOR $1000
Build Date: 1999
Mileage: 20,000
Bottom End:
Windage Tray
Top End:
Induction:
Accel Distributor
Misc:
TRANSMISSION $600
Car: 1988 Camaro SC
Engine: LT1 SBC
Re: 350 SBC & T5
Bump - I have a deposit on the transmission.
Will sell carb / intake / dizzy separately.
Car: 1988 Camaro SC
Engine: LT1 SBC
Re: 350 SBC & T5
Transmission is sold.
Motor and accompanying parts remain!
Will accept offers.
Will accept offers.
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
Re: 350 SBC & T5
how much for the serpentine brackets to 71047? I need the two aluminum brackets, idler, and water pump pulley.
thanks, Greg
thanks, Greg
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Eric-86sc
Aug 24, 2015 09:01 PM
