[IN] BBC engine cfe big chief heads tunnel ram dual dominators etc
Old Sep 24, 2013 | 12:51 PM
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
4.840 bore spacing. Lightened melin block 438" bbc. merlin block 4.625 bore 3.250 stroke. Bryant crank, mgp alum rods, gas ported venolia pistons. Reactor flexplate, ati balancer. Moroso dry sump oiling system [pan, pump and tank].Moroso vacume pump. 55mm cam, jesel keyway lifters,jesel belt drive and jesel front drive dist. CFE olds big chief 14* heads rolled to 10*. tit valves. flow over 500 on int. CFE sheetmetal ram w/twin 1050 dominators. Moroso sheetmetal valve covers. csr starter. Engine is fresh. Heads are off for inspection of buyer makes roughly 1000 hp. Moroso vacumm pump setup, electric water pump
Engine is fresh. Fresh line hone, bearings, and rings..
8,000$
Text or call James 317-752-7406 jgillen91@yahoo.com
Have more pics.
Located in indianapolis.
Old Sep 27, 2013 | 11:14 AM
91_B4C_RS's Avatar
Re: BBC engine cfe big chief heads tunnel ram dual dominators etc
Make offer!!!
Old Oct 1, 2013 | 11:35 AM
91_B4C_RS's Avatar
Bump!!!!!!
Old Oct 2, 2013 | 09:13 PM
91_B4C_RS's Avatar
Ttt!!!!!
Old Oct 3, 2013 | 11:20 AM
91_B4C_RS's Avatar
Price reduction 10,000$ alot of parts for the price
Old Oct 22, 2013 | 07:54 PM
91_B4C_RS's Avatar
Bump it up!!
Old Oct 29, 2013 | 08:14 AM
91_B4C_RS's Avatar
8,000$ its urs!
Old Oct 31, 2013 | 11:39 AM
91_B4C_RS's Avatar
Bump
Frozer!!!
Jan 19, 2024 04:55 PM
onefreakz
May 14, 2018 12:15 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
L98GTA87
Aug 11, 2015 06:55 PM
