Built 350 aluminum headed longblock 400hp $1500
Car: 86 iroc
Engine: Iron 408 LS3 combo
Transmission: Ram10 T56
Axle/Gears: 3.73 10 bolt :)
Small block 4bolt main 350 .30 over built by Precision Engines... long block only . Less than 20k on everything , edelbrock rpm heads, rpm cam , full roller aluminum crane rockers, double roller timing chain, Trickflow balancer Moroso pan, Melling high volume oil pump, arp hardware ... Engine runs great you can hear it run before purchase. Call me with any questions as I do not check my emails.. Thank you, Adam 810-772-0073
Car: 1989 Firebird Fornula 350
Engine: 350 L98 / NOS
Transmission: 4sp Auto
Car: 86 iroc
Re: Built 350 aluminum headed longblock 400hp $1500
Anything in specific ? I can take some when I get home
Car: 86 iroc
Car: 86 iroc
It's a roller block but the cam is hydraulic flat tapet
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
bump for a good deal!
Car: 86 iroc
same price $1500, ill throw in the poly engine mounts and an aluminium performer intake
ambainb
Apr 25, 2016 09:21 PM
