[IL] Spindles and brackets for LS1 brakes
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have a set of spindles and brackets to mount a pair of LS1 calipers. I had an extra set of spindles and the needed metal so I made this pair. The spindles are from an 85 Camaro. The holes/bolts are standard thread and not metric. I believe that I used 1/2 threads instead of the 12mm that many use. This set was never mounted so it is possible that the spindles would need a slight amount of final clearancing. I took my time on making the spindles and took all of the rust off and smoothed the entire piece(s) down then primered and painted them.
These do not come with bearings or races or hubs or rotors or calipers or abutments or ball joints.
Bigbrakeupgrade.com charges $75.00 to modify spindles that you provide and $59 for the brackets. I believe that $175.00 shipped would be fair. I am open to trades if you have something or offers if after a few weeks they are not sold. They must be sold together and don't even bother PMing me if you are going to offer $100.00.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Genopsyde
Nov 11, 2015 10:46 PM
