Holley Stealth ram SOLDDDD!!!
Old Nov 29, 2013 | 02:41 PM
84'B.A.T.A.'s Avatar
Car: 88 Iroc-Z
Engine: 388 HSR
Axle/Gears: 9 Bolt 3.70
SOLD
Old Nov 29, 2013 | 02:44 PM
Car: 88 Iroc-Z
Engine: 388 HSR
Re: Holley Stealth Ram Setup
Also forgot to mention if buying whole setup I will include coil/ distributor, all wiring, sensors and ecm for extra $250 for everything
Old Nov 30, 2013 | 11:17 AM
seahawkfan's Avatar
Car: 91 z28 1le
Engine: 5.7
Axle/Gears: 3.23 now 3.73 auburn hd
Originally Posted by 84'B.A.T.A.
Really clean stealth ram setup. Only used at the strip four times this year. car ran mid 11's N/A with this intake. Twin 58mm pro products throttle body. Red anodized billet fuel rails. 36# bosch injectors. all precut cut and assembled -8 and -6 braided lines with fittings that hook directly up to factory tpi fuel lines! If you are looking at complete swap I will also be selling all sensors as well as computer and wiring.
$800 OBO without wiring/computer/sensors
pictures???
Old Nov 30, 2013 | 12:12 PM
Car: 88 Iroc-Z
Engine: 388 HSR
Originally Posted by seahawkfan
pictures???
Old Nov 30, 2013 | 12:34 PM
truckerz's Avatar
Car: 1989 Formula
Engine: 355ci HSR SBC
Would you consider parting out the fuel lines separate? I have a SR myself, but don't have the braided lines.
Old Nov 30, 2013 | 12:35 PM
Car: 88 Iroc-Z
Engine: 388 HSR
I actually cant in order for those billet rails to work I had to have a fab guy drill 1/2" holes where the stock rails mounts. Then fill with tig. and retap for alignment. It looks factory now but I cant part it as its technically a custom piece.
Old Nov 30, 2013 | 01:42 PM
truckerz's Avatar
Car: 1989 Formula
Ok, thanks, and GLWS!
Old Nov 30, 2013 | 05:25 PM
Car: 88 Iroc-Z
Engine: 388 HSR
No problem, Thank you!
Old Nov 30, 2013 | 06:43 PM
duke22's Avatar
Car: 1988 IROC convertible
Engine: 5.7 TPI
Axle/Gears: 3:73:1
Will it work with a maf sensor?
Old Nov 30, 2013 | 06:44 PM
Car: 88 Iroc-Z
Engine: 388 HSR
yes that's what I was running
Old Dec 4, 2013 | 01:44 PM
Car: 88 Iroc-Z
Engine: 388 HSR
Very nice TB!!
Old Dec 4, 2013 | 04:24 PM
duke22's Avatar
Engine: 5.7 TPI
Axle/Gears: 3:73:1
Re: Holley Stealth Ram Setup New lower pricing willing to split!!!
pm sent
Old Dec 4, 2013 | 05:08 PM
Car: 88 Iroc-Z
Engine: 388 HSR
pm sent
Duke, it must not have went through.
Old Dec 4, 2013 | 07:19 PM
duke22's Avatar
Engine: 5.7 TPI
Axle/Gears: 3:73:1
Ill try again
Old Dec 7, 2013 | 01:37 PM
Car: 88 Iroc-Z
Engine: 388 HSR
Re: Professional Products 58mm TB
TTT
Old Dec 8, 2013 | 08:12 PM
Car: 88 Iroc-Z
Engine: 388 HSR
TTT
Old Dec 9, 2013 | 01:09 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
pm sent
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
